Panther G
Panther G
Here is my Tamiya Panther G that is getting close to being finished. It has the TBU but I'm at a loss as to where to put the IR LED.
https://youtu.be/3AoxbH-MX0A
Drill out a hole in the Mantlet for an IR emitter tube. Did mine through the existing main gun sight. If your looking to be tamiya compliant it needs to be 9mm deep to front of bulb and no wider than 6mm ID. These are the same specs as the stock tamiya clip on emitter holder. Vid worked for me. Nice build!
Whatever makes you happy though.
