Andrews Design Sd.Kfz 2 Kettenkrad 1:16 x 2
The only problem is that I have to remount mostly all Kettenkrad to get the gearbox out.. And I didn't made any blueprints of it. So I can give You just approximate dimensions - 36x20x20 mm. I used 3x6x2,5 bearings for motor axis and middle wall and flanged 3x6x2,5 bearings for the side walls...I used n20 motors with ratio 1:150 and these gears:
http://www.conrad.com/ce/en/product/5472...t=detview1&rb=1
Best regards,
Edmunds
Best regards,
Edmunds
#33
Ohhhh you really maked me jealous with your goliath with anhänger. It almost beyond awesome. I soooo would like them to make the goliath into production.... I defently would try to make the goliath r/c converted! If you ever get tired of it I got a kettenkrad waiting to tow it so make me a call
//Sebbe
//Sebbe
#39
Hi, Sebbe!
The Goliath is to be found on the shapeways.com
https://www.shapeways.com/product/RJ...ionId=61424378
#40
So is the Kettenkrad, RSO tractor and many other pieces but I doubt they can be RC'd. There's even a 1/16 M5A1 Stuart available in both static OR has the separate parts to RC that.
Mind you, these are not cheap and we're not talking styrene either.
#41
If there's idea to make an Rc Goliath, it should be made scratch for 100%. I have been thinking about it and using 1:35 model metal tracks... But there's sooo little space inside. As an option could be usage of the transmission from these small 1:72 Rc tanks
#42
I have the styrene Dragon kit in 1/35th and like you, have a few 1/72 RC tanks which the tracks and gears would be perfect.
Jeff
Jeff
#44
I think the Goliath's tracks are simple enough to fabricate or at least cast in resin.
Too bad the shapeways listing calls the rear wire guide a 'wheelie bar'.
Do you guys think there would be an interest in a working model of a Goliath?
Beautiful work on the 3rd Ketten by the way.
#46
Thanks for the tips about the 3d printed goliath! Not as good as yours but at least a start!
A RC version of the goliath should be possible using a small servo motor or similar. Best for space would be to find extremely small bevelgears and install the motors like the real thing, in the sides. It can be done I think so someone must try! Im working with a Sol models Zundapp 750 1/16 rc conversion and its possible! Steering servo hidden in the engine with only servoarm sticking out and electronics in the sidewaggon. I also made a RC conversion from the black box toys 1/6 goliath but it was a lot more space there... (didn't work so well unfortantly...)
Good luck with your new kettenkrad!
//Sebbe
//Sebbe
#48
Those things are so neat.
#50
