Close-Up images of WWII Panther turret track hangers needed
I need some images of the turret track hangers that the WWII Panthers used... A, D or G as it doesn't matter.
I can figure most of it out but pictures tell so much more than using 1/35th as a reference.
Thanks and have a Safe New Years Eve!
Jeff
Jeff
There were many types all field made and attached in different places even the tracks were hung differently depending on which Division the tanks belonged some divisions didn’t use tracks on the turret sides, it would be far simpler to say which Division you wish to depict in Italy Russia or France, tracks were also hung horizontally and vertically, this subject is very complicated and even people who know what they are talking about sometimes get confused
Happy New Year.
Happy New Year.
Thanks guys for your replies and Happy New Year!
I had no unit or division in mind... just ANY close-up images would help me decide if I want to do this or not. I have also seen blurry images of what appear to be what was used for attaching them to the hull for the turret as well which was a new discovery for me.
I am just considering attaching links vertically to a late G and I have a good idea as to HOW, but an education on the subject is always a better step forward.
Jeff
Jeff
Those are the style typical of 1st SS Pz Div - made from steel rod and welded to the roof. Other units welded the hooks to the sides of the turret, either from rod or strip.
It's definitely a Panther built after August of '44.
I wanted to take a Late Production G (with the last station a steel rimmed road wheel) and make a command tank out of it. Since there are limited photographic images of them, instead of the foliage loops welded on the side of the turret, track links sounded better for such a Panther.
I don't want them "magically" hanging there so some type of hangers will do since they were field applied. Round steel rod is the more logical choice and most likely to be more readily available.
Thanks for everyone replies!
Jeff
According to http://the.shadock.free.fr/Surviving_Panthers.pdf that one is ex 1st SS as well - interesting that the hooks are made from strip rather than rod, but then its an earlier tank than those I have studied for my Kampfgruppe Pieper group build...
That pdf also lists another ex LSSAH example in the Canadian war musuem that looks to be similarly made from strip, but the basic principle remains the same - welded to the turret roof rather than the sides.
(OMG, I have become such a nerd about this stuff... )
LOL you Big Nerd...you are always a big help so it's all good
Not a great shot, but here's how I did mine:
1mm diameter brass rod, bent in such a way that I could hang a HL track link from it if I wished. the end is bent over to plug into a hole drilled in the turret roof, so that it will hold up to a little bit of handling in service - not strictly to scale or accurate, but one of those compromises you have to make on a battler if you want it to last...
Nothing wrong with being nerdy at all. I'm a HUGE fan and primarily interested in Panthers and Shermans... so naturally I know a bit more on those 2 AFV's then anything else. Collecting as much reference material helps too. Too bad it didn't apply to my Sturmtiger build back in 2005 where I learned blurred images from the Internet and museum pieces do not show they all had zimm... except for the prototype.
I knew Panthers turret hung track links were a field modification... just not a lot of clear images to be found on the net or in printed material as to what it looked like, so I asked.
So this week a trip to get some brass if I don't have the rod here in my heap of materials. I do thank everyone on their help to provide images and info where you're never too old or never know too much.
Jeff
Jeff
Hey Jeff,
Not sure if your still looking for these, but I just found a couple of pics of the Panther at the Canadian War Museum, Ottawa...
Also http://hobbyhavoc.com/forum/index.php?topic=3144.0
Oh wow, thanks so much Larry! Those are VERY helpful and only confirm that round shaped rod was the most preferred material.
I AM going to use them on an Early G now instead of a Late G, but the pics helped so much!
Jeff
Jeff
I guess you can draw 2 conclusions from this - either by some miracle all of the preserved Panthers with turret track hangers are ex-1st SS PzDiv, or few other units bothered with fitting them to the turret?
rex
