Custom arduino controls / tracked vehicle driving algorithm (Video)
Hi guys,
I put together an arduino control system for my Torro KV2 a while back, but finally got around to making a video to demonstrate it. The video just demonstrates the driving algorithm - throttle, steering, inertial movement, etc.
Happy to share my code for anyone interested. I think it's a very "realistic" driving algorithm, and also highly precise (at least using the ETO gearboxes). Anyone interested in creating their own electronics for custom projects or etc might find this useful.
https://www.youtube.com/watch?v=VDiT1ozRKQU
My apologies for the very quiet audio track - first time using my new sony action cam and I guess I need to really be speaking right at the camera or have an external mic. You'll have to turn up your speakers.
Anyway let me know if you have any feedback or would like to see the code.
Lets see if I can post code.... this is not the complete arduino project but simply the key components of the driving algorithm so you can see how it works...
Code:
//CONTROLLER INPUT throttle=map(CH3, 1065, 1900, 0, 127); steering=map(CH1, 1065, 1900, -127, 127); //Throttle: postive forward / negative reverse. Steering: positive left / negative right. //In this example throttle is mapped for the full motion of the stick to be forward, for more precision. //For forward/reverse on same stick (center neutral), you'd map -127 to +127 instead. //INERTIA //savedthrottle variable is initialized as 0 //steermargin is set to 3 (out of 127). //The lower the number, the less input variation is required to trigger "smoothing" of the input if(abs(throttle-savedthrottle)>steermargin){ if(throttle>savedthrottle){ throttle=savedthrottle+steermargin; savedthrottle=throttle; } else { throttle=savedthrottle-steermargin; savedthrottle=throttle; } } else { savedthrottle=throttle; } throttle=abs(throttle); //Map the steering min/max so that it is no greater than the throttle input //In other words, the steering is proportional with the throttle steermap=map(steering, -127, 127, throttle, -throttle); steering=abs(steermap); //Set steering left or right, to determine which motor to "brake" in next step if(steering<0){ steerswitch=1; }else{ steerswitch=-1; } //Depending on left or right, pick which motor to modify. The other gets the straight throttle input. //Inside track braking is simulated by subtracting steering input from the throttle of the inside track. //dirswitch is the forward/reverse switch (+1/-1). if(steerswitch==1){ ST.motor(2, (throttle-steering)*dirswitch); ST.motor(1, throttle*dirswitch); }else{ ST.motor(1, (throttle-steering)*dirswitch); ST.motor(2, throttle*dirswitch); }
I didnt create any IR battle system but I imagine you could do so using the arduino platform. I have seen some examples of interpreting IR signals. It can be done, but would be a challenge I'm sure.
I have made a full Tamiya compatible IR battle system using an Arduino processor, I do like your control algorithm, the control looks very smooth! I made my controller so I could create a tank that can battle using brushless motors. It works very well on the low ratio gearboxes but does have a tendency to 'handbrake' turn changing from straight ahead to turn when running at full speed. I'll study your code and see it I can use it to calm my tank down on the turn!
I have since done away with the actual Arduino and made my own board which makes the tank wiring much easier to use.
Drew
Drew
This looks really cool. I just have no experience at all with Arduino. Wouldn't mind using it in my 1/6th scale KV-2. It runs at 24V for the motors. I guess I'd have to incorporate another lower voltage battery or use a voltage step down circuit to run the Arduino. Maybe a future project once I get some of the other projects done I'm working on.
Rileyelf, when looking at my code just try to imagine the way a full size tank works.
The inside track is slowed proportional to the throttle and steering inpuTs. And the speed of the outside track is never greater than the throttle input.
The smoothing comes from Comparing each new throttle or steering input to the previous input, and if it is greater than a threshhold (you could call this An inertia factor) then the new input is limited to a certain Level above the last input, and new inputs are generated over time to get you to the actual stick position.
Hope that description helps elucidate the code a bit. The control really is fantastic, very finite, and took several iterations to get there. Would love to see your fInished product.
MI
Hello Pedzola,
Thank you for sharing. I too am interested in developing my own tank driver.
Dimension Engineering has a youtube channel and they showcase their Kangaroo 2 module for their motor controllers like the sabertooth. You should check it out. It adds PID control. One thing these tanks all need in my opinion.
Are the motors your using have encoders? Hard to tell from the video.
Space is a big consideration for these tanks as well as clean wiring. My tanks have airsoft units, so they extend downwards near to the floor of the hull. Thus, that area must be kept clear. They also have 360 deg turret rotation so wiring must be tucked along side and away or else they'll get yanked.
Currently, I have stock Taigen/HL controllers, a new IBU3, and an Elmod Fusion Pro in my tanks. Of these three control boards, the Elmod was designed to simulate the motion dynamics of a real tank that is coupled to a sound generator, and it does this very well. It even jerks forward during simulated gear changes, and does skid turns like you've programmed.
The worst is the stock electronics, and surprisingly the new IBU3 falls right in the middle, but I'm still getting to know it. It's at firmware rev v0.11 too. I'm hoping down the road the makers focus on the driving dynamics in later revs. But overall these all-in-one boards are great buys.
For my own custom endeavor I'm looking at...Arduino pro minis for R/C -to-motion drives and another for turret controls/video, a Roboclaw motor controller, a Benedini TBS mini for sound, and both a 5.8ghz, and 1.3 ghz fpv system fed from various micro cameras that depict the commander, gunner, and driver views.
It's not going to be cheap! Especially when you compare it to an all-in-one. The only reason I'm taking on this experiment is for the limited space in my smaller tanks - Sherman and Stug III. An all-in-one eats up too much space. In addition, the mcu's are fun to play with and they do simplify the wiring and hardware overall.
