Need some Tamiya Sherman parts
I am looking for Tamiya Sherman rear tail lights. The plastic housings and lenses.
Also looking for part B-18. Styrene part from B tree that goes between 30.cal machine gun barrel and the brass LED housing.
Hi Guys
You might want to try these - http://www.shapeways.com/product/M4Q...i=shareProduct - they're designed to fit around a 5mm LED, with slightly ground down bulb - for the Sherman, just cut off the 6 bolt tabs.
Mal
Mal
Yes I did, I opened it last night thank you.
Any luck on the tail lights?
Those 3d printed ones look good but with the screw tabs around the outside they are post war through nam era. The tabs would have to be cut off and the housing shortened a bit.
