Painting tips for Jagdpanther?
Thanks for your painting advice and how you did your project. I am going to follow your procedure and hope I get the results you got when I paint some of my backlog of German tanks that I want to do with camo paint schemes. I can do a paint job that looks like something that just rolled off the factory floor, but weathered paint is not my strong point by any means. Also, I think learning to do road dirt and battle damage might go a long way to cover up my mistakes and inaccuracies. Your posting was good timing!!!!
rex
rex
I like using pastel chalks for weathering because if you screw up they will wash or even rub right off.
This is my first attempt at weathering a model. It's much easier than I expected. I'm using black to get into crevices to bring out detail. I have been mostly using a dry sponge but also a wet/damp small brush allows you to drag the muck into crevices. When it dries, you can rub away the excess with a bit of sponge, leaving dark grime in the recessed areas.
I'm also using brown to create a dirty look.
The red makes nice rust, especially on the tow cable, which I painted with a metallic enamel.
Steve
Steve
Your posting is kicking my memory in the butt --- I looked for some stuff I bought a long time ago, never used, and forgot about. I'm going to give this stuff a try on a practice piece to see if it is any good anymore, it's been in a drawer for about 20 years.
Has anyone out there ever used this stuff?
rex
rex
rex
rex
The box reminds me of an item someone trying to sell potions and miracle elixers Step right up get your bottle now before it's too late .....lol
but they look cool Rex let us know how they work out
A bit more work tonight. Sprayed on some dull coat, then added a bit more weathering, including some rust. Also I've added most of the accessories. Body is almost done. My wheel mask should be here any day so I can paint the wheels and get them back on.
Steve
#34
Custom looks way better!!!!
