Reload this Page >
New Tamiya jagdpanzer Lange 1/16 scale
Old 05-20-2016, 07:04 AM
karel47
karel47's Avatar
a bit more pics guys so here they are
the specs are clearly stated at the board
Old 05-20-2016, 08:00 AM
Panther F
Panther F's Avatar
Thumbs up
Oh wow... metal wheels. Did the Panzer IV have them as well? I missed that then.
Good pics!
Jeff
Old 05-20-2016, 11:04 AM
DaveBcool
I have to think those metal wheels are part of someones custom build and not Tammy's.
The front fender is metal also, and screwed on.
Clearly not a stock kit.
Old 05-20-2016, 11:16 AM
Panther F
Panther F's Avatar
Red face
That's what I thought but didn't want to ASSume. Very misleading.
Jeff
Old 05-20-2016, 05:14 PM
Imex-Erik
Imex-Erik's Avatar
Yea those look like our road wheels, but it is hard to tell. It looks like they might have hubcaps on them though, which would not be ours if so.
Old 05-23-2016, 03:01 AM
  #31
Shergertank
sorry I don't mean to interrupt or steal this post but I just want to ask in order to build these Tamiya full option kits do we build then paint or paint while building what do most of you do
Old 05-23-2016, 03:25 AM
  #32
BludoTheSmelly
BludoTheSmelly's Avatar
You're fine, never hurts to ask questions.
Old 05-23-2016, 06:51 AM
  #33
DaveBcool
Generally, (especially with your first kit) build up the kit first and get everything working.
I leave off some smaller details, such as some hand tools to paint first then add later.
You may also want to leave off smaller moving parts such as hatches or travel locks so you can paint both sides and they don't get in the way.
Then partially disassemble to paint items separately for the primer and base colors.
Then remove and paint separately: Turret (sometimes main gun too), upper hull, lower hull, sprocket, idler, and road wheels without tires
Then add those elements back if doing camo pattern.
Old 05-23-2016, 07:06 AM
  #34
Rustytrax
I have done it both ways. My prefered way for german armor is to PRIME in red oxide then assemble. I then paint the model before the running gear and tools are applied.
Old 05-23-2016, 07:34 AM
  #35
Shergertank
thx
Old 05-23-2016, 07:36 AM
  #36
Shergertank
like the 1/35 th or static ones model glue is needed right?
Old 05-23-2016, 07:51 AM
  #37
Green Amphibian
Green Amphibian's Avatar
Yes on the glue and some good plastic safe lube for the gearboxes.
Herman
Old 05-23-2016, 08:57 AM
  #38
ausf
ausf's Avatar
Tamiya is unique in that their RC kits are a combination of their static model arm and their RC arm. They assemble as easy as any static kit, yet they're engineered to last.
You'll need a few different glues on a full option kit: normal styrene glue (like Testors), a MEK or methyl chloride based (like Tamiya Extra Thin, Tenax, PlastiWeld) for the ABS and ABS to styrene and finally what they call rubber cement for the few instances where you'll be putting non plastic parts together like the MG LEG flasher to the barrel, but that cement can be anything from CA to PVA.
Tamiya uses ABS on their road wheels and high stress areas like the barrel to recoil connections. They tend to over engineer their stuff, I don't think it's necessary since they earlier full options didn't have a problem. No big deal, you just need to be aware so you don't expect a normal styrene glue to hold the few ABS parts. Everything is well marked on both the directions and the sprues.
You can use Tamiya Extra Thin on the whole model to be safe, but the stuff works so quickly and evaporates so fast that a normal tube of styrene glue is easier when applicable.
Both types work by melting the parts together, but ABS needs a stronger solvent.
Old 05-26-2016, 08:02 AM
  #39
karel47
karel47's Avatar
the foto with metal wheels was posted by mistake , are upgradeparts not in the kit
Old 05-26-2016, 09:02 AM
  #40
BludoTheSmelly
Do we know what they will run at this option ?
Old 05-26-2016, 09:21 AM
  #41
karel47
karel47's Avatar
not much , so speculating does not help , we will see when its released
Old 05-27-2016, 09:15 AM
  #42
karel47
karel47's Avatar
you are looking for those , were produced by mk.modelle.de wich is out of business 5 years ago
this is mine
am now busy on an 251/1 ausf C uses ludwigs motordrive and ketten
it was an almost total conversion, the innerdetails of the mk modelle were quite wrong and lacks many futures the real ones had ... so i love details and busy now on four of them 1/16 full rc hanomags ausf D and C
these are different stages of the build , its straightforwarded those hanomag halftracks made of styreen , plastic melted as one body ... its fun ...for now
ID:	2164398   Click image for larger version
ID:	2164399   Click image for larger version
ID:	2164400   Click image for larger version
ID:	2164401   Click image for larger version
ID:	2164402   Click image for larger version
ID:	2164403   Click image for larger version
ID:	2164404   Click image for larger version
ID:	2164406   Click image for larger version
ID:	2164407   Click image for larger version
ID:	2164408   Click image for larger version
ID:	2164409   Click image for larger version
ID:	2164410   Click image for larger version
ID:	2164411   Click image for larger version
ID:	2164412   Click image for larger version
ID:	2164414   Click image for larger version
ID:	2164415   Click image for larger version
Old 05-27-2016, 09:16 AM
  #43
BludoTheSmelly
I like
Old 05-27-2016, 11:10 AM
  #44
CHIEFSONN
CHIEFSONN's Avatar
It looks as if Tamiya made the periscope traverse with the main gun,something i'm working on my Jagdpanther, will have to look into that. i noticed that they did not go and add the steel wheels to the tanks front for the extra weight of the gun.
Old 05-27-2016, 11:13 AM
  #45
BludoTheSmelly
December cant come soon enough.
Old 05-27-2016, 12:12 PM
  #46
MAUS45
MAUS45's Avatar
Nice Catch ChiefSonn!!! I have lookedat the photos over and over again and missed that detail. Really nice touch and hope it's not just part of the test shot for the shows!!!
Old 05-27-2016, 04:18 PM
  #47
DaveBcool
How are you coming to this conclusion?
Old 05-29-2016, 09:51 AM
  #48
MAUS45
MAUS45's Avatar
10th photo in post #26 it has enough space in the opening for the site periscope to travel with the gun traverse.
Old 05-29-2016, 11:26 AM
  #49
ausf
ausf's Avatar
Look towards the end of this video at the closeup, peri moves with traverse:
https://www.youtube.com/watch?v=SUTk2GnlB6A
Old 05-29-2016, 11:30 AM
  #50
BludoTheSmelly
Good find!
