Im thinking about buying a King Tiger.
Hi all. I thinking about buying my last tank. Im pretty sold to the Tamiya King tiger just because I love assembling my kits. I would like to ask what you think I should upgrade. So far I've read many times I will need the following:
Gearbox brace. The DKLM looks what I need.
Better track tensioners. No idea what to buy here.
Tracks: Here I have read mixed reviews. Some people says those tracks lasts for years and some other say they will break in the first run. I run my tank everywhere so I need something strong. What do you recommend me here, as cheap as possible? Not sure if mato tracks are compatible.
Also Im a bit annoyed with the hatches in the KT. All of them are closed, so what do you recommend me here?
Thanks for your time!
I think Taigen/Asiatam do some working hatches. I've had a couple of Tamiya King tigers and I found the only upgrade really required is an idler upgrade. You can fill the spring bits on the stock one with putty which works well but the Schumo or hentec upgrade is relatively inexpensive so a good place to spend your coin. If your going to use low ratio gearboxes the stock tracks might struggle, I've seen them break when people use impact tu or the Schumo geardowns (which should be avoided under all circumstances). The Tamiya King tiger lacks a bit of detail but even built stock with a nice paint job makes a lovely tank.
So far my idea is either to use stock gearboxes or if I upgrade, I would use that new DKLM gearboxes, but Im not sure if they will fit without drilling the hull.
I saw thosse schumo geardowns in axels modellbau shop, and looked like a gread add to the KT. Why we should avoid them? Quality problems?
And yeah, I have seen some masterpieces, painting here and there will make it a lovely tank. Just I was a bit annoyed that I have some 1.72 scale kits and I can open and close the hatches there. Its unveliebable that this feature is not stock in our tamiya kits.
Thanks for the tips, Tom. Yep, I have seen some people filling the iddler with putty, that`s a good tip. And if its cheap its double good tip
I think they did new molds when they released the henschel turret, but it was in the 90s... But yeah, I understand what you mean. When I assembled my sherman the moulds dated back from 1975! Those might be the most profitable molds ever.
About the geardows, that makes sense. I will stick with the stock ones until they fail.
Again, thanks!
Again, thanks!
Again, thanks!
Again, thanks!
If you upgrade to metal tracks you will need to upgrade your transmission system. DKLM is marginally better than the stock but before you buy you need to look at my systems, which are virtually bolt in. Shipping time to you from my city is about two weeks. With my single main frame system you will not need a hull brace for the transmission.
http://www.etoarmour.com/product_det...?productID=S01
Sevoblast, im afraid I can not pay that amount of dough for the motors. They look rock solid, but is just too much.
I have never tried the DKLM gearboxes but a great thing that it has is that the tank will always run straight. Thats a big plus for me.
Tom: Dont forget you can also use the ASP 2 for the DKLM gearboxes, lol.
On the Tamiya electronics there is a trim tab so you can adjust the steering to always run straight when your radio stick is self centered.
The electronics are 100% plug and play, but I find them boring after a while.
