Dialing in turret rotation speeds.
I have been upgrading my Taigen tanks with TK22 boards. The transmitter I am using is a Turnigy 9x. The 9x allows me to adjust the mixing to set the maximum rotation speed but I have a problem with tanks that require a really slow speed.
Has anyone used this product and if so what are your impressions?
http://www.rctankelectronics.com/sto...ive_gears.html
I'm thinking this combined with the 9x mixing just might give me the results I'm looking for.
The easiest and cheapest; put a 17-22 ohm 1/4 watt resistor, or a 50 ohm variable resistor in series on the red wire to the transverse motor. This will slow the movement speed, you'll have finer movement but slower rotation from original.
Cheers
AK
Cheers
AK
I have a KV-1 that I am trying to set to a 360 degree rotation of 60 seconds. It's not possible to set it that slow by adjusting the radio transmitter throwpoints. Doesn't lowering the throw point on the radio transmitter do the same thing as using a variable resistor? I would think changing the gear ratio and making minor adjustments to the throw point settings would be more efficient.
Maybe I'm using the wrong terminology. My transmitter is set up to control the turret rotation with channel 1.
Channel 1 mix source is rudder with a weight of 30.
Channel limits I have set to -90 left, 55 right.
The different settings in the limits is because the motor operates at different speed depending on direction.
I may be wrong but I thought the weight determined the amount of step and the limits determined the sensitivity.
The weight I use for a course speed adjustment and the limits allow me to fine tune the speed.
If I reduce the weight much more I lose torque and the turret stalls.
If I reduce the limits I get the same result.
My thoughts are the gear selection of this new turret motor will allow me to use a better gear ratio with more weight in my mixer setting to give me more torque at a slower speed.
I was curious if anyone has tried the new style motor assembly that I posted in my original post.
I also use mixes for having dual rate in the throttle, but the motor start to turn when the torque is greater than the friction of the system
Not sure how those gears available work with that unit. In other words if it's not spring loaded or adjustable how do you compensate for the distance gained or loss between it and the ring gear?
You can also replace the motor with a lower RPM motor at the same rated voltage.
For instance, in my case I had a roughly 11000 RPM motor for one of my tanks rotation and replaced it with a 21000 RPM motor for faster rotation (almost 2X)
If you want slower rotation, find a similar can size/rating motor with the RPM ratio lower you desire.
