IBU2 Base with TPA
HELP with IBU2 Base and TPA
Hi everyone, I'm new to installing the IBU2 base unit with TPA to my Torro Jadgtiger. I have some issues with my unit I need help with. I am using the stock battery that came with the tank. 7.2 2000mah. Do I need to configure anything from the controller or the SD card?
1. Volume is very weak even though I tried to adjust the volume knob that came with the TPA unit with speakers included.
- FIXED! = I have to rearrange the wiring on the JST pins on the volume knob of the TPA.
2. No smoke from the TARR unit and I already tried holding on the fan. I have the MK1 version. Using Taigen oil.
3. Also how do I get the barrel recoil to work properly as it is not consistent. I have the IR version.
Thanks in advance.
Thanks in advance.
On the recoil issue, check to make sure the trip arm is being properly contacted when it recoils. I used a Tamiya Pershing recoil unit with mine and I fixed it by moving the arm forward and installing a washer on the rail to help it make contact when it goes through the motion.
Hi, I saw your question at my youtube channel so if I were you I would first try just one speaker without the TPA. If you get good volume there at least you've narrowed the trouble to the TPA. Nevermind, just saw you got that sorted out.
What TX are you using?
There is a dipswitch that you flip for nihm or lipo, so be sure that's properly set. I THINK it's 4 and should be off for nihm, but confirm that, K?
Recoil timing is on the micro SD card. It can be difficult at times. Have you got a card reader?
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
I'm using a FS-CT6B transmitter.
Yes I do have a card reader. May I ask whats your settings?
Here is a photo of the switch
could it be my battery is not strong enough for the TARR unit and the gun recoil?
also what is the red wire coming from the board?
That wire coming out of the MFU is a ground for the recoil, I do believe. It's not present on airsoft tanks. On my IR Tiger One it's attached to the on/off switch. This could be part of the recoil issue. When you had the MFU in it, where did you plug in that red wire from the MFU and what's plugged in there now? My JT is airsoft so the wiring is a bit different. Have you got a photo of the upper hull that shows the wiring coming down?
I'm not sure about the TARR. I bought one but it never worked right out of the box so I went back to the stock smokers or the ones I beef up myself.
In the IR Tiger I think the recoil is set at 1500.
Where did you get the IBU?
Your dipswitches look good. Mine are set a bit different because with airsoft I don't use the reload delay so the only switch I have on is #4 because I run lipo. Do you just have the one battery? Definitely make sure it's fully charged. Low battery can wreak havoc.
<iframe width="560" height="315" src="https://www.youtube.com/embed/EmCl1bLZrzI" frameborder="0" allowfullscreen></iframe>
