It has arrived...
It has arrived...
#23 of 50....
4 boxes.... all roughly 22kg each...
One box has ONLY 200 track links, pins, and road wheel tyres....
That is an A4 sized certificate and the PE grills underneath.
Unfortunately Assembly will have to wait while my Garage get overhauled... New electrical & a Milling Machine inbound...
Soooo excited.... Barrel is as large around as my thumb almost...
I just saw a 1/6 scale Maus at rctanks.ru, but they don't list a price. What a beast that thing must be in 1/6 scale!!
http://www.rctanks.ru/radio-controll...maus-1-6-scale
These tracks are massive... I purchased the last of the Mark-1 Maus Spare Tracks in my Maus project research...
I'll try and put up an image tomorrow for scale comparison...
It used to be...
If you picked it up direct... Plus extra and shipping otherwise...
[TABLE="class: cms_table, width: 500"]
[TR]
[TD]Maus 1/6th
Maus 1/6th Radio Controlled Model Tank
Price: £3,700.00
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
Unpainted Rolling Chassis only
Painted in a base colour, with 6 Channel RC, Turn turret, Gun elevation and Twin ESC (correct engine sounds), Speakers and Battery. Ready to go (+GB£700.00)[/TD]
[/TR]
[/TABLE]
[TR]
[TD]Maus 1/6th
Price: £3,700.00
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
[/TR]
[/TABLE]
Specifications
The hull, top and turret are constructed of high density GRP up to 35mm thick, making them extremely strong, but light. The wheels are cast Aluminium, with rubber tyres where specified. Suspension beams are hardened steel with cast aluminium drop arms with coil sprung suspension. The Motors have an integral reduction gearbox, with external chain drive, very smooth, efficient, and reliable. There are over 70 bearings in each Tank. The performance of these Tanks needs to be seen to be believed, being very powerful and robust. Maintenance is minimal. The tracks are a Zinc/Aluminium cast construction, with stainless steel pins. Performance is 3 to 7 mph depending on gearing choice, climbing 60-degree slopes with ease, and able to go through any surface. Running times depends on type, scale and surface conditions, but all will run for a minimum 1 hour, most over 2 hours, longer with bigger batteries. The Tanks can run through water safely over the track top height, sometimes more!
These Models are extremely robust, and thrive on running, yet remain as practical as is possible with any large scale RC Tank.
Approximate 1/8th, 1/6th or 1/4 all up weights are:
[TABLE="width: 70%"]
[TR]
[TD="width: 33%"]German
1/4 King Tiger - 250kgs
1/4 Tiger 1 - 240kg
1/6th Maus - 150kg
1/6th Leopard 2 - 95kg
1/6th King Tiger - 95kg
1/6th Jagdtiger - 90kg
1/6th Elephant - 90kg
1/6th Tiger 1 - 85kgs
1/6th Panther - 85kg
1/6th Jagdpanther - 80kg
1/6th Puma - 50kg
1/6th 251 - 40kg
1/8th Tiger 1 - 35kg[/TD]
[TD="width: 33%"]Allied
1/4 T34/85 - 200kg
1/6th Challenger 2 - 95kg
1/6th Comet - 75kg
1/6th JS2 - 70kg
1/6th ISU 152 - 70kg
1/6th T34 - 65kg
1/8th Abrams - 40kg
1/8th AAVP7A - 40kg
1/8th T90 [/TD]
[/TR]
[/TABLE]
[TR]
1/4 Tiger 1 - 240kg
1/6th Maus - 150kg
1/6th Puma - 50kg
1/6th 251 - 40kg
1/4 T34/85 - 200kg
1/6th Comet - 75kg
1/6th JS2 - 70kg
1/6th T34 - 65kg
1/8th Abrams - 40kg
1/8th AAVP7A - 40kg
1/8th T90 [/TD]
[/TR]
[/TABLE]
