Mato Sherman M4A1 Metal upgrades?
Hello, Well I finally found a discontinues Mato M4A1 Sherman. I found one in the UK and its one its way. Does anyone know where I can find metal upgrade parts for it? Thanks, Rob in Illinois
Etoarmor.com also carries alot of great metal detail parts.
I would also reccomend that you upgrade the turrert on your tank since the mato one is fairly ugly and not right.
christian lidwig makes one or you could put a taigen turret on like I am working on doing.
have fun.
have fun.
Like i said, 130 is bucks for a taigen 76mm turret. But problem is it wont just fit right on the a1 hull, you will need to cut the hole in the hull bigger like i did and move the rotation gear box.
or you can cut the circle out of the bottom of the turret, then cut the circle out of the bottom of the mato turret and affix it to the taigen turret. ive done that twice now. Its some work but it can be done fairly well.
