Taigen/Torro Jagdtiger question
Haven't had this happen before, maybe one of you guys will know what the problem is. I plugged the battery into it's cable and turn on the tank via the control box and one track starts moving at full speed. I've tried starting it with the transmitter on and off but same result. I'm thinking maybe the board is cooked? I've also taken all the wires out and check connectors and posts but they all look to be in good order. Help!
By "box" You mean the 2.4ghz RX18 lookalike tank controler used in Torro/taigen tanks?
You could try re-binding the transmitter and receiver. The manual should give a good description of the process.
The tank should not have control of the tracks until you start the tank with the transmitter. If you power the mb and it immediately runs a track it is most likely time to replace the board.
You can open the tank and unplug the motor wires and see what else works or to try and rebind it and then plug the motors in to see if that fixes it. Make sure the tank is sitting on a block or the treads are removed just in case it takes off!
