The Exotic One - RC 1/16 Type 97 Shinhoto Chi-Ha - scratch built
The Type 97 Chi-Ha was the second most built japanese tank in WW II (besides light Type 95 Ha-Go).The initial version used the short 57mm gun, that couldn’t deal with enemy tanks. Therefore a new, longer gun (caliber 47mm) was developed and mounted 1942 - 1943 in a redesigned turret. This type was designated Type 97 Shinhoto Chi-Ha and was built in 930 numbers.
Starting the report with some design development:
The kit:Again, this kit is a cooperation of Christian Ludwig and me.
…to be continued…
…to be continued…
You have my attention. I like the Ha-Go but this is interesting!
This is looking close to being finished... very soon!
Any plans for optional turrets (like the Chi-Ha) for this chassis later on?
Why not also a converted Chi-Ha? It´s depending on the interest at the market, but should be no big deal.
Nice progress.
There are no „standard“ gears available, that fits in the tiny front hull, so only one way is possible: to build customized ones.Size 25mm gear motors are used; they are strong enough for this lightweight tank.
The housing is made of glued 3mm aluminum sheets:
All parts of the gears…
…and mounted:
Originally I plan to use Pz. III return rollers…
…but then switched to scale printed roller mountings and using the smaller early Pz. IV return rollers…
…and Pz. III metall tracks which were cutted on each side to get overall track width of 19mm.
I think it´s looking well
Freddy
…and mounted:
Freddy
Now, to acquire a Mitsubishi SA12200VD air-cooled V-12 diesel sound!
Tracks and lower hull looks great!!!
THAT'S good news, since that chassis was used the most. I wouldn't mind seeing a few open turret kits too, like for the Type 1 or the Type 3 HONI-III tank destroyer. AFV's with detailed breach and figures visible is always appealing.
How long did it take to cut the tracks?
That´s why is called modelling or model making ... I´m kidding
I guess this will be only an option - if ever...
But if you compare the picture it´s not that bad with no reworked Pz. III tracks:
Attachment 2248451
Attachment 2248452
Attachment 2248453
Attachment 2248451
Attachment 2248452
Attachment 2248453
Next step: the turret.
These are the main parts of the turret:
Building at first a rack…
…for mounting the mantlet.
The gun have to be mounted from the inside, fixing with some plastic Sheets.
Accessoires at the backside of the turret:
Finishing the turret with the roof and commanders cupola.
That means, the kit of the Type 97 Shinhoto Chi-Ha is ready built, but needs a lot of bolts, hinges and handholds…
