How to replace headlight on Heng Long Jagdpanther?
So according to my voltmeter, I'm getting juice at the headlight, but no lighty. Strangly the voltage reads between 480-500 volts, depending on whether I set my multimeter to 1.5, 9, or 12V. I don't know why.
But, the volts go away when the tank is shut down, so I'm assuming I have juice at the bulb.
So, how hard is it to replace the headlight? I'm guessing it's glued into the socket on the fender? I suppose I can cut it off flush with the socket, then drill out the remnants until I can glue in the new one.
Speaking of new one, is there a more accurate replacement with the horizontal slit instead of the bare bulb nose?
Steve
Steve
These are what I used on mine (well, one of them anyway). Just use some de-bonder, like "Uncure" and after a minute or two it should wiggle right out.
TIGER 1 METAL LED HEADLIGHT
I replace the LED in this with a warm white 3mm LED.
And I believe you're getting 4.8 to 5 volts at the lights, so use an appropriate resistor if you change the LED, otherwise the one that comes with the metal light will work fine, just wire it in.
