7.4V battery for Heng Long PIII?
As far as I remember heng long uses the old tamiya conectors...Those are know for being very bad and old connectors and the popularity of them is at the bottom of the ocean right now... So Id choose a battery with XT60 connectors. Deans if you want something smaller. Both of them are very easy to solder, and no need of any crimping tool.
Lipos will need a different controller because they require low voltage cutoff to keep them safe. I guess you could use the HL controller if you installed an inline low voltage battery cuttoff. If you want a straight drop with the same connector you should stick with a high quality NiMH battery. I had a Traxxas one that I wasn't using and soldered on the Futaba connector that HL uses.
These will work, 7.2v is ok for the Panzer III. They have the Tamiya connector as well.
https://www.ebay.com/i/122550908478?chn=ps
7.2V NiMH are ubiquitous and available everywhere. They are a direct drop in replacement.
https://www.amazon.com/s/ref=nb_sb_n...A7.2+volt+nimh
I am not aware of 7.4V NiMH packs as that is a standard Lipo voltage. I am not aware of any Lipos with the HL Futaba style connector.
I would not recommend using a tamiya style connector on a lipo battery. They are a crimp type connector that are only rated for 15 amps and are prone to mechanical failure.
But if you insist on using that type of connector you could try contacting Maxpacks. You can choose the type of connector you want.
https://www.maxxpacks.com/
So, since I have 3 of the 7.2V bricks (NiMH, NiCD) I carved open the P3 battery box so I can fit a standard-sized battery in it. I figured 7.2V would work fine in a 7.4V system.
But with a full charge the tank would only run a couple of minutes before it bogged down and stopped running. It has no smoke or sound so the only thing running are the motors and receiver.
Please do listen to my advice though and think twice about running a Lipo into the HL electronics without some sort of low voltage cutoff if you have to have a Lipo.
Steve
This is the battery that came with my Heng Long PIII:
I don't have a picture of the battery compartment handy, but it has a "step" in it, so that a standard 6-cell pack will not fit in it. I cut the step away to put a 7.2V 6-cell pack in it but it only runs about 3 minutes before dying. I'll try another 6-cell pack.
Steve
Steve
hmmmm,
That is a Lipo.
I think I understand what is going on here. I bought my PIII years ago and it came with the standard 6 cell NiMH pack. In fact they came with Nicads way back then.
It looks like you have a recent PIII version with the new 2.4 GHz electronics and those do use a Lipo according to the Mato site. It is a 1.8Ahr - 7.4V which seems pretty small to me.
I wouldn't have guessed it without seeing the pic. Maybe someone with more experience on the HL 2.4 GHz system can comment.
That is a Lipo.
Steve
Man, I am confused as to what you have then. I don't know where you bought it and who would sell that configuration. Non S&S electronics from 5+ years ago mated to a Lipo battery. What is this craziness?
