Taigen upper &Tamiya lower hull
Reply
Old 03-14-2018, 06:03 AM
wsn123
wsn123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Taigen upper &Tamiya lower hull
Is Taigen KT upper hull with metal turret
https://www.taigentanks.com/taigen-p...t-jt/tag120284
fits Tamiya KT lower hull?
wsn123 is offline
Old 03-14-2018, 06:33 AM
Imex-Erik
Imex-Erik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One sec and let me get you a few pics
Imex-Erik is offline
Old 03-14-2018, 06:48 AM
Imex-Erik
Imex-Erik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok so "technically" it should fit. However it isn't a swap and go as there will be no latch system and the middle brace for the turret will have to be trimmed down before it sits correctly on the lower hull. I don't believe it is enough to have to lose the brace, but you will need to trim those middle posts down and figure a way to latch it. After that there is a bit of a gap in the front as well that will need to be filled, but other than that it looks like it would be a good fit I never finished my KT build so I had it sitting around. I was actually cleaning my office recently so I already had it out.
ID:	2259183   Click image for larger version
ID:	2259184   Click image for larger version
ID:	2259185   Click image for larger version
ID:	2259186   Click image for larger version
Old 03-14-2018, 09:09 AM
wsn123
wsn123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Imex-Erik: thank You very much for help and attached pictures , now all its clear.
One more question: is HL KT upper hull size and shape excately the same as Taigen once?
Is Taigen KT upper hull with metal turret fits HL KT lower hull also ?
wsn123 is offline
Old 03-14-2018, 10:27 AM
Imex-Erik
Imex-Erik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The HL one is very similar to the Torro one but without the bracing, upper hull latch molds, and the accessories on the Torro version one has metal tools instead of the molded on ones. As for compatibility it will partially fit but it made for the metal editions as it kind of expects you to have the latch system. Although with that nice big rear hatch I'm sure its no big deal to make a switch panel
Old 03-14-2018, 12:41 PM
wsn123
wsn123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Imex-Erik: Thank You very much for explanations
wsn123 is offline
