How to charge this battery?
I bought this 7.4V Li battery for my Heng Long P3. I cut the connector off of it that came with it and put the Heng Long Tamiya connector in its place.
https://www.ebay.com/itm/7-4V-1500mA...r/323043050526
I have a Venom PR2 charger. On the Lithium Ion setting, it has 2S - 7.2V, and the next step up is 3S - 10.8 V.
This is a 2S battery but is 7.4 V.
Should I charge it on the 2S-7.2V setting?
It came with its own USB style charger which I'm sure you all will disapprove of.
Steve
Steve
It sounds like your battery is a Lithium Polymer and not Lithium Ion. Lithium Polymer batteries have a nominal voltage of 3.7v per cell which is why yours says 2s 7.4v on the label.
I use LIPOS a lot and only ever charge them on a LIPO charger making sure that the balance connector is plugged in. LIPOS are extremely dangerous if not charged properly so beware.
Good luck
CaptB
Good luck
CaptB
