Asiatam Opel Blitz Control Board Question
Not sure on that one Gary, even if it does handle 12V bigger question may be if it'll handle the amp draw. Kinda heavy vehicle with not the smoothest gearbox. Any actual markings on it other than Asiatam to possibly look up specs from the maker? Guess the other question is why do you even need 3S? 8.4 should be plenty for a 1/16 scale truck.
Thanks, Bret, but I got it. 3S works fine, gives just enough extra top end. I'll have to time it, but I'm thinkin' I've got about a scale 30 mph top speed right now, still a bit slow but close enough for the girls we go out with. The new batteries should fit snugly between the frame rails with a 3D printed box, which is the next step.
If you want more top end could look into a larger pinion and window out a motor mount hole for the motor to pivot and allow for the larger distance between pinion and gear.
