Taigen V1 gearbox/HL
I have a HL Panzer III and wondering if I eventually wish to change to a gearbox with Steel gears if the Taigen V1 set will fit the HL or if their only designed for the Taigen PzIII.
Being new to RC Tanks May I ask I’m under the impression that Taigen Tanks are basically upgraded HL Tanks would this be correct.?
Larry.
Larry.
Hi Larry,
You raise a bigger question than I think you expected.
I assume your Heng Long PZ111 has Nylon Gears and Wheels and Tracks,
That is a very nice combination and if you should decide to "Fight" your Tank it will be a satisfactory set up,
If you decide to change to a metal Gearbox set you then enter the law of diminishing returns,
Metal gears pretty much demand metal Sprockets and idlers and of course with them you will need metal wheels and you might as well have metal rollers and with that lot metal tracks are a must,
If you fit metal gearboxes I would certainly fit Gearbox output shaft support bearings as well.
How does your pocket book feel now ?
The Taigen 5 to 1 Gearboxes Product Number TG 1203-s are priced at 65 Euros they should be available from "IMEX" in Florida and are interchangeable between Heng Long and Taigen Panzer 111s.
They are a very nice all bearing set,
As to the two company's, They used to be loosely tied together but that was some years ago and they are now quite separate BUT many parts are interchangeable between the two,
If you have any doubts ask us and someone will help you,
Shaun.
Shaun.
Hi Larry,
Shaun.
Shaun.
this all came about cuz my panzer III when it arrived had a broken idler rim, my thinking was instead of cheap plastic just replace the sprockets and idlers with the more durable metal ones then after ordering them and reading the forums felt the metal tracks would be preferable to plastic.....as for the gearbox’s haven’t as yet settled definitely on changing them but felt if I did the Steel gears would be preferable to zamac or the cast metal ones, for what I’m using my tank for ,running around the house or backyard might very well be going overboard! 😂
Hi Larry,
Shaun.
Shaun.
lol Shaun,
Sooo if I understand you correctly I should just probably replace the sprockets and idlers with the parts I already have and when something breaks worry about standard or upgrading parts then’ makes perfect sense! TTUP’
Yea I would start with the gearbox and just enjoy it from there. The upgrade path I suggest is gearboxes>drive wheels/idler wheels>suspension arms>road wheels>tracks. I mean don't get me wrong we all like metal but sometimes it doesn't serve as good as a purpose as you would think it should.
