M548 tracked cargo truck
Old 07-27-2018, 10:53 PM
JulliPolas
Default M548 tracked cargo truck
How's this for a project?
This is a M548, a cold war cargo truck used until today
My project it's kind of ambitious with scratchbuilt body and well,almost everything else, real 1/10 (25cm x 58cm,replica suspension system)
Do you like to see it?
Old 07-28-2018, 07:01 AM
armornut
armornut's Avatar
Attachment 2261364
heck yeah I'd like to see it. Tracked non combat vehicles are great. Halftracks are even better 😁
Old 07-28-2018, 07:32 AM
RichJohnson
RichJohnson's Avatar
I know someone that owns one of these and drives it around the back country streets on evenings lol.
Old 07-28-2018, 01:11 PM
JulliPolas
Must be fun although they aren't very stealth at night with that diesel 2 stroke that sounds awesome
Old 07-28-2018, 10:33 PM
JulliPolas
Ok guys... I've started this some time ago and kept it in a restrict circle until i see i could pull it through
Backstory: a 1/10 Unimog build was in a standstill, needed more fabrication and the motivation had died off. One night, saw the ad for a mobile war game featuring a curious looking tracked truck. Did some research and fell in love for a truck so ugly that's almost russian
Talked to a coworker(ex-military) about it and not only my country has them but he rode one while in service
To the build!
Because this truck was a side affair, tried to go slowly, only to see where it would lead
Size compared to a rc4wd D90
First cuts:
the nose:
Test fit:
Back to the nose:
The 1:1 has 2 headlight clusters, containing regular headlights, blacklights for stealthiness, horn, blinkers,etc(depends on the variant). on mine I went for regular lights, red lights to simulate the blacklights and horn
Tought in machine them but 3d print makes it easier,machined only the housing and the lenses were cut from 1:1 car lights:
Old 07-29-2018, 02:53 PM
JulliPolas
The running gear will be metal heng long gearboxes:
They came with tiny motors(280 or 370) so I had to adapt them to 540 motors. Seemed easier, one done:
This running gear is perfect for this truck. 2 gearboxes with 1 motor each seems that would take too much space but no:
They sit perfectly under the cab floor like the 1:1 and the bottom of the gearboxes align perfectly with the underside
The complete running gear it's 2 motors, 2 ESCs, 1 battery . I was afraid of having to buy a stick radio like all tank guys have but I've tinkered with my usual radio that offers 4 mixing slots and have found the perfect way. Progressive control in both throtle and steering
They I found that a V-tail mixer from airplanes allows to use any grip radio.
Old 07-29-2018, 03:32 PM
sassgrunt
I really like what you are doing to build this vehicle. My favorite variant of this is the M727 Hawk missile carrier; I always thought it had a cool factor that few other vehicles did. Keep going - I am enjoying your build thoroughly!
Old 07-30-2018, 04:26 AM
JulliPolas
Thanks! It's really an cool looking truck. Tracks make anything cooler
more stuff:
Added the side windows
these rear vents:
Most of the m548 I've seen online(and the ones on our national army) have canvas top but i found that are hardtop variants and knew right away that's the best option:
so, stacked a couple of layers of pvc and tried to do the round corner windows
Old 07-31-2018, 12:03 PM
JulliPolas
This is the passenger door:
I wasn't planning on opening doors but someone ( ) convinced to do them and being honest,looks better and helps with the interior
Next, I progress on the "dash",the real one is barebones,military style
Mine it's not 100% accurate but after paint and details, I think it will look good enough
The dials extend to the other side of the sheet metal ,will have wires behind to simulate the connections and only the tip of the LEDs will be showing
Old 07-31-2018, 10:26 PM
Tanque
Tanque's Avatar
Very interesting project. Good scale!
Jerry
Old 08-01-2018, 04:13 AM
JulliPolas
Thanks! It's an odd scale for a tracked vehicle but it's doable and will look good on the side of my other truck, also 1/10
Made the passenger bench
Bishop seems to like it
Old 08-01-2018, 12:19 PM
JulliPolas
started the roof:
It's far from finished but I need to sort out the interior before gluing the roof and give the final touches
Did the tailgate too:
On the 1:1:
I assumed that the tailgate can be opened to both sides so I went with it
Basic shape, 2 layers of PVC and one of the hinges:
Closed:
One way....
...or another
Old 08-02-2018, 04:10 AM
JulliPolas
After some thought if I 3d print the traction wheels or machine them, went for the 3d print because of their complex shape
the 1:1
Mine have more teeth because of the different design of the tracks
Unfortunately, miss the teeth pitch and it doesn't lock properly with the track. Back to the drawing board to modify the teeth....
Old 08-02-2018, 08:51 AM
MAUS45
MAUS45's Avatar
Nice progress and looks great so far!!!
Old 08-02-2018, 11:59 AM
JulliPolas
Thanks! The most interesting stuff it's yet to come
Small stuff, added the steps:
I sanded them better after these photos
And because sometimes photos can't show the proper size of scale trucks, there's something for reference :
Old 08-03-2018, 04:26 AM
JulliPolas
Had the chance to make the hull. Had to bent a 0.8mm aluminium sheet and now with the angle grinder I'm making the last bends. Rivets to hold the corners and epoxy to reinforceThe truck it's very dirty because of handling it at the shop to fit the hull
Front:
Bottom:
Gearboxes in place:
​​​Click image for larger version
Not having the "hull" done, delayed progressing on the body. With the hull, everything is figured out.Another view of it,to show better how much space it has for transmission and eletronic
mAh for days....(actually, I'll use only 1 battery, 2 if the stress it's too much)Click image for larger version
Was planing to do these "fenders" as part of the hull but they were looking bad:Click image for larger version
This section was also to be in aluminium but because the hull is removable, there will be gaps showing, so I enclosed it in PVC. Now it's easier to add details
Then, made this bulkhead(?) with service panels for the engine
Old 08-04-2018, 03:43 AM
JulliPolas
This time didn't do much visible. Lots of sanding and trimming. The most visible chance was the floor of the cargo bay. Had the piece cut from the beginning and now it found it's place
First, some reinforcements :
Then, a kind of hatch to change batteries:
Maybe some magnets to close properly:
Tailgate on:
Old 08-04-2018, 01:26 PM
philipat
This is awesome! Nice to see another build on the forum.
Old 08-05-2018, 03:34 AM
JulliPolas
Thanks! This is my first tracked vehicle and second scratchbuilt body
Well, I can't leave the truck unattended...Seriously,cat? Click image for larger version
I was figuring out how to close the doors. Seems to work this way: (animated GIF)
Old 08-05-2018, 02:26 PM
JulliPolas
I wasn't liking the squareness of the rear. Looking at more photos, realize that was a mistake. Redone it with angled sides:
Got the cushions for the seats:
The footrests:
And the levers to steer:
Tried running a gearbox on the hull. The gearbox is loud and the metal hull amplify that. Guess I'm not needing a sound generator
Old 08-06-2018, 10:45 PM
JulliPolas
Hi,
I had trouble solving how to do these small mounts for straps:
Well,the easier way was designing them and print:
This mounts are for holding tools on the 1:1. An axe, picaxe,sledgehammer and shovel. Quit of doing the picaxe because there wasn't enough space for it
First one:
Second:
Third:
Old 08-06-2018, 11:28 PM
Tanque
Tanque's Avatar
Very cool!
Where did you get the Villam Defoe figure!
Jerry
Old 08-07-2018, 04:13 AM
JulliPolas
Originally Posted by Tanque
Very cool!
Jerry
It's Bishop from the Alien movies. 7" figure from Neca
Old 08-07-2018, 07:44 AM
Tanque
Tanque's Avatar
Lance Henriksen? Ok I can see that...
Old 08-07-2018, 11:59 AM
Crius
I believe the pickaxe was carried with the head separated from the handle. I'm sure if you try hard enough you can squeeze it in there somewhere.
