Reload this Page >
What size socket headed cap screw to use as M2 nut driver?
Reply
Old 01-14-2019, 06:00 AM
maillemaker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default What size socket headed cap screw to use as M2 nut driver?
I just ordered some M2 Hex Head Bolts to attach the Mato Sherman idler brackets / tensioners to my plastic-hulled Heng Long Sherman.
I don't want to spend $20 on a set of nut drivers.
Does anyone know what size socket headed cap screw I need to buy to use as a M2 nut driver?
Steve
maillemaker is offline
Old 01-14-2019, 07:20 AM
jarndice
Location: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know if this helps but the Minimum width between the Flats of an M2 Bolt is 3.82mm,
The maximum width between the Flats of an M2 Bolt is 4mm.
Shaun.
jarndice is offline
Old 01-14-2019, 11:51 AM
RC_BobM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If the M2 is 4mm across flats of hex -you'd want an M5 SHCS. The key (hex size) size for M5 is 4mm.
RC_BobM is online now
Old 01-16-2019, 02:38 PM
Imex-Erik
Imex-Erik's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On most M2 bolts it will be a 1.5mm hex bolt. This may be different depending on the type of head of the M2 bolt, it might also be a 2.0mm hex but most likely it is 1.5mm hex if you got a M2 bolt. I'm not 100% positive on the size, this is just going from my experience with M2/M3/M4 hardware that I work and play with.
Imex-Erik is offline
Old 01-16-2019, 05:45 PM
maillemaker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the RC scale M2 bolts today - yes, they measure about 2mm across the flats.
Steve
Old 01-18-2019, 06:21 PM
RC_BobM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If that's the case then a M2.5 SHCS should work as a driver. Seems odd a 2mm dia screw would have a 2mm flats head - but for "scale" screws probably true. Try M2.5 socket head screw as driver. The hex socket size is 2.02 / 2.08mm for a M2.5 Socket head screw.
B
