Converting Henglong from 27Mhz to 2.4
Converting Henglong from 27Mhz to 2.4 and other mods
So, like the tile says... Smoked my 27 control board in my Jagdpanther so got the 2.4 setup. So, everything is working, but controls are wonky. and not sure how I can change it.
Mods and results:
- Smoker works as expected, on/off from the Tx (eliminated the switch on the tank)
- Gun didn't work, so had to resolder the +/- the other way (then it worked). Also eliminated the gun switch, made a custom breach block and stiffened up the spring for more power
- Sound effects work as expected (actually better after building a custom speaker box with FRS 8 speaker). If only they did proportional speed/sound it'd be pretty good.
- Swapped over to 2S Lipo with 5000mah - Much better
- Added FPV to the commander's cupola
Control craziness:
Right Stick
- Right goes forward
- Left goes backwards
- Down reverse spins to the right (I think)
- Up reverse spins to the left
Left Stick
- Right and left move the barrel up and down
- Up and down don't do anything except sound effects
- Up/Left + shoot button fires cannon.
I tried swapping the motor leads but that just made it even goofier. Very counterintuitive Any way to change that?
Mods and results:
Control craziness:
Right Stick
Left Stick
I think you have a bad 2,4 MFU, probably some MOSFET burned. I wouldn’t spend money in HL 2,4, instead I would get Clark directly, with not much work is almost plug & play.
The HL 2,4 Ghz MFU have a horrible firmware you can't turn proportionally.... garbage, I have a pile of them with their Tx all replaced in favor of Clark with a Turnigy receiver and Transmitter
Ok so try swapping the positive and negative wires on either the plug or motor (whichever is easier for you). I think that is your issue I see this a lot when people wire up their own motors, sometimes the positive/negative wires are different from the factory and the default motor rotation is backwards. If it was just the plugs in the wrong way the tank would drive forward and back fine but spin in opposite directions when turning. Try this to see if I'm right:
- Start the tank.
- Unplug the passenger side motor. We will start with the driver side.
- Press forward on the drive stick, the driver side motor should move the track forward. It should also move backwards when going in reverse. When you turn to the right you should see the track go forward (super spin) and when you turn left you should see the track go backwards. If your track does not follow this pattern then swap positive and negative wires at either the plug (easier) or motor and try again.
- Diagnose the passenger side. The same is true forward and backward, though the direction for the turning will be backwards. Right turn = backwards while the left turn = forwards.
- Start the tank.
Thanks.. I'll report back after I take it apart for the 400th time lol. I need to trouble shoot the gun anyway - I think the barrel is blocked a bit.
Need help to
I know this post was a long time ago but I have just started the exact project you have completed & would love to get any wiring diagrams & photos you might have regarding the conversion, I've looked everywhere and found nothing, any help would be great thanks
Seems I've made a mistake in the purchase of my new Transmitter it is still actually a 27mhz unit henglong 1/16 smoking R/C tank parts 27Mhz transmitter radio controller with RX-18 main board/TK-18 receiver which I believe with the multi function board will allow me to add the smoker unit at least.
