1/16 centurion
1/16 centurion
LONG POST WARNING!
Hey folks,
I'm looking at thinning the herd to free up space for other projects, as previously I'm going list all my completed tanks and will sell what I need, if you really want get in there quick
More picture/videos/build threads are avalible, let me know what you need.
All located Northwest Manchester. I would prefer collection but postage at buyers cost and risk is possible. Payment by cash or PayPal friends and familly
Tanks for sale:
M51 :
Tamiya based, mato upper, tamiya super Sherman turret, scratch built engine deck, schumo travel lock, schumo radio box, schumo engine hatch, schumo Jerry can holders, schumo two cables, scratch built rear stowage and side stowage bins. tamiya electrics with kv-1 mfu for correct engine sounds, custom commander figure. £850
https://youtu.be/GdCisb2M62E
King tiger:
Torro full metal, upgraded extensively. Zimerite removed on hull, servo elevation and recoil,DKLM PDSGB (gearbox), led flash, hidden ir emitter, RCTA tiger ring hidden ir sensor, Clark tk60 sbus control board, flysky 10 channel reciver, FR7 speaker and 3dp speaker box, mk modellbau 3m and command star antennas, fuel breathers, schumo tow cables, schumo tow cable holders, schumo comanders mg mount, schumo mg34, fine line hull mg34, Shapeways tool clamps, Shapeways fire extinguisher, killer Gary farrow ardennes camo scheme. £850
https://youtu.be/V87hW1-91zU
Chris Ludwig Cromwell:
Asiatam brass low ratio gears (the good ones!) Ludwig sprockets, metal idlers, henntec tensioner, Clark tk60 sbus, flysky 10 channel Rx, servo recoil, Hidden battle system, besa mg removes to show the emitter, one crew figure, lots of Shapeways detail parts, working hatches, FR7 speaker in custom enclosure £900
https://youtu.be/Uzof0Lf2m00
Composite firefly:
Mato full metal lower with t74 duck bill tracks, ibu3, tamiya speaker, one off composite resin upper and turret, dklm metal recoil and elevation, tbu base, hidden emitter, coax mg (needs rewiring), shapeway periscopes, schumo scope guards, lot of scratch building, metal Churchill track applique armour, British commander figure. 50cal in pictures not included. Schumo tow cable set. £850
https://youtu.be/fjpBV9RpH8s
Jan/Feb 44 tiger:
Taigen metal chassis, wheels, tracks, sprockets and idlers, taigen 4 shaft steel gears. Upper and turret are heavily modified merit items. Loaders and commander hatch opened up on turret and driver and radio man's on the hull also. Voyager photo etch set with Aber tow cables, Ludwig travel lock, Worden handle tools and photo etch tool holders. Atak zim. Hidden IR emitter, tiger ring hidden IR reciever, servo recoil, xenon flash, fine line mg, Clark tk80 control board, FR7 speaker. £650
Jagdpanzer l70 lang:
Heavily modified chassis, strengthened with angle alloy and styrene, metal wheels with rubber tyres, asiatam steel wheels for the front 2 positions, track tensioners,steel gear boxs, Clark TK40 sbus control board with 5w amp, FR7 speaker box, hidden IR emitter and tbu base, resin conversion heavily modified for accuracy, working metal transmission inspection hatches, engine hatches and driver and gunner hatches, fine line head light, etch checker plate, scratch built antenna and cleaning rod holders, spare wheel holders, track holders, rear engine deck scratch built to correct size and correct slope, tank modellbau removable side skirts, mk modellbau mantlet and turned barrel, wooden jack block, tank modellbau convoy light, scratch built late exhausts, shapeways tool clamps, tools have wooden handles. Beautifully painted in hard edge camo scheme with custom painted xion commander and gunner.
Pm for price
Taigen Sherman m4a3 76mm mostly metal:
Metal chassis, bogies, wheels, sprockets, idlers, tracks, turret, IR version with recoil and smd high tension flash, 360 turret and slip ring, electrics upgraded with ibu2 UFO. £400. I can also supply a variety of tamiya sprues to upgrade the detail.
T-26 sterling tank transporter and M16 trailer.
Believed to be unique. 6x8 configuration currently (although could easily be made 8x8). Cab is styrene, everything else is metal, tamiya truck Axel's driven through custom transfer box (using mechano brass gears so easily replaceable), running an MFA geared motor (looks like 600 size). Trailer has properly 2 axis pivoting bogie, motorised ramps, the parts for motorised legs. Comes with two crew figures. Paint and a couple of details could use tidying up, but a really great, unique vehicle that will pull any 1/16 tank off road. £900
https://youtu.be/hKNe6_NPyVw
Centurion mk3
A unique opportunity to own a 1/16 Centurion MK3 of the King's royal Irish hussars early in the Korean conflict.
She's very much mixed media, made from styrene, many 3d prints parts, details in brass, real wooden to handles, resin crew, cloth mantlet cover and resin stowage from value gear.
She comes with the crew shown, drivers from DGS models and the rest from the now defunked tw-modelltechnik so good luck finding others like them!
She has servo recoil and elevation, led flash, coaxial mg led, hidden ir emitter, tbu base. She's running a Clark tk60 v3 sbus, fr7 speaker in a big box, finally shes propelled by a dklm PDSGB.
She's painted with acrylics, weathered with oils and oigments. There are cast and roll armour effects with Mr surfaced too. I hope you like her.
She runs really well, even on thick grass (see video) and makes and awesome battler.
https://youtu.be/ydyCHi0xDFo
I'm happy to ship, antennas would need to be removed but they're easy to reattach. Shipping worldwide at buyers cost and risk
I'm after £1100 for her collected from Manchester. (Postage depends on location, insurance etc).
Chevy c15ta truck.
3d printed, 4wd, lots of nice detail. Comes with esc and steering servo
£90
17lb anti tank gun. Great companion to the Chevy truck, printed by Frank heritage with metal mato gun barrel.
£70
Sent from my SM-G950F using Tapatalk
Hey folks,
Tanks for sale:
M51 :
King tiger:
Composite firefly:
Jan/Feb 44 tiger:
Pm for price
Centurion mk3
Chevy c15ta truck.
£90
£70
