6-wheeled Sd.Kfz.231 Beginning of Wehrmacht reconnaissance the build report
Usually I’m designing tracked RC vehicles, but sometimes I switch over to other genres.
Since a very long time I wanted to have a 6-wheeld recce car Sd.Kfz.231 and after WPL/JJRC released their trucks, it was possible to use some parts of their chassis.
Here are some pictures out of the design phase.
Base is the chassis of the JJRC Q60 (WPL B16 isn’t possible to use because of its different rear axles).
Some parts of the kit:
Let’s start the build.
Preparations of the resin printed hull.
Reworking of the JJRC axles.
Tapping the axle’s end…
The original gear motor is too weak, so I’ve designed a stronger one.
...will be soon continued :-)
Cheers,
Freddy
Cheers,
Freddy
The following 2 users liked this post by Panzerjaeger66:
rivetcounter (08-24-2020),
Rjag (08-10-2020)
Panzerjaeger66 (08-10-2020)
Thanks guys for your interest
Some progress and details at the lower hull
until the lower hull is finished.
Next step means the upper hull. An overview of the parts
and done so far
and done so far
Saw this kit on the internet without the motor, electronics or axles and they wanted 565 euro for it. In my opinion that's a total rip off and the seller should be ashamed of himself. Hell, I've got a Sd.Kfz.250 tracked vehicle that came as a kit in 1/6 scale and I only paid $300 for it. There's a difference between making a fair profit and rippin' folks off and at more than $660 USD this is way into the rip-off category. I don't care how long it took to design, that's still less than $10 worth of plastic and should cost NO MORE than 200 euros. Just an opinion, but I think it's a valid one.
Less work at the turret is needed...
For easy moving, flange bearings are used.
The build is done so far
After applying light grey primer and Tamiya TS4 the shape is much better visible .
Available will the kit be here:
https://www.fertigungswerk16.at/shop-fahrzeuge/
Wow!!! This looks great!!!
Nice! Would kill for it to be 1//10.
Great work!
Great engineering job, how much time between designing, modifying, test printing, reprinting, sourcing parts (Motor, Gears, etc.) and hardware, modifying parts, final printing, assembly and final testing do you think you have invested in this project?
How much time for just the final printing of parts?
What resin printer do you use it looks like it can print fairly large projects?
Steve
Steve
That's a very well planned and executed build, this must have taken quite some time to design.
If you could buy x4 of the steering axles it would be possible to build an Sd.Kfz.232
Great work!
Steve
Steve
Thanks for your interest in this build!
All my designs are in corporation with friends, so designing and building (not manufacturing) the protoype is my task. This 6-wheeled armored car was printed from my friend Lukas of fertigungswerk16, so he knows much more of printing data or type.
Usually I need approx. 9 12 month for designing and building a kit with all improvements (time span for manufacturing included) to get it ready for production. In this case the Covid19 situation gave me much more time all day to invest so it needed about 4 month to get it ready with several test printings and design changes.
I guess for (re-)designing approx.. 300 - 400 hours was needed.
Pretty cool!
Panzerjaeger66 (09-16-2020)
Concrete work in the town is amazing!!! The 6 RAD running and painted looks great!!!
Panzerjaeger66 (09-19-2020)
