HENG LONG OWNERS ONLY THREAD!
#51
NY
RE: HENG LONG OWNERS ONLY THREAD!
Titan, since this is a HL thread only I would not be able to show you a pic of a Tamiya King Tiger goind through mud and snow. Ha ha
Seriously though. Again, I know that Tamiya users are not supposed to respond on this thread but how are the suspensions on the HL? Are they stiff, to loose, can you adjust them? How is the gear boxes? Do they grind when stuck? How heavy is the tank and what % grade can the tanks climb? Sorry for the questions, I am just curious because I may want to invest in one. I have a Tamiya, nice but expensive. Thank guys.
#52
QC, CANADA
hl suspensions are too stiff, it depends if you wanna add more accessories.
suspensions can be adjusted simply by drilling another spring attaching hole near the original one or by adding weights.
the motors are strong, the climbing angle or degree ,depends on the traction, not the motors.
this tank is little more fragile then your tamiya, but it is fast and easy to fix(fun) when sad things happens and parts are cheap.
so
if you can use a screwdriver and a soldering iron for wires,go for it,
you will enjoy this 99$ tank.
take the s&s version with metal gears ,
no plastics gears>safety clutch does`nt last long in rough conditions .
so
#54
I can see now why HL can run in water ...it's very easy to water proof I sealed my M41 with rubber seals and moved the switches from the bottom and sealed the holes the Sherman is not water proof it only has flood cells in to to control water intake.
HL wins the "Water Proof Award" as well as "New Tank Award"
#55
WHAT? This is MUTINY, hand in your Tamiya Snob Club badge NOW, CJ
ORIGINAL: CJ Mahoney
#56
QC, CANADA
sherman seams to be the best tank for that purpose the front is very high.
i do`nt know if i would have the guts do it with a tam.[sm=thumbs_up.gif]
lift my hat to your braveness cj [X(] .
#58
QC, CANADA
hi guys ,
have sealed the lower hull on mine ,
but water came in buy the top hull holes and i forgot to seal the 2holes of the front tracklinks holder(rack) that i have removed since sealing.
i took the chance at the end of the day ,since i have other boards and
15$price .
still not finished the cleaning of tank and waiting to see what the speaker will say once dried.
cheapy video editing is almost finished about 8 minutes long .
working on the sound track .
#61
I'd love to Pantherize it! I'm waiting for someone to make a kit, I don't have the talent or time to do it from scratch. As for the 9, for awhile every time I made a bid on e-bay these guys outbid me, so I made 3 lowball bids and won them all! Those guys must have felt pitty and let me win for once. That was fun explaining to the wife!
#62
Two HL Tigers - or rather one Tiger and one being modded into an ARC (armoured Ramp Carrier), yes, it was British thing (Churchill ARK) but hey, it was an idea and just had the first test run and all OK but now electrics have died.... I used the traverse motor for powering winches in/out and elevation unit to select between winches. will try and get some photos when I can but for now I have to get the multimeter out and found out why it stopped.
Anyone have any circuit info on HLs?
#64
QC, CANADA
swathdiver>>> the same for me , would like a panther too, but it looks like a long project to pantherize , guess we will have to find motivation one day to do it .
i do`nt think hl and
tam will produce one soon.[&o]
#65
Tiger Tamer reporting in.
Following previous problems (see Heng Long Failure) have now received a replacement Tiger from supplier who also refunded post costs of 49 euros .
Replacement tank runs great at the moment and even smokes ! Which is probably tempting fate.
Anyone else got a "Berlin Tiger" as I would like to know what is the paint colour.
If you do get one of these "factory paint jobs" which appear to be recent circulations, watch out for the selotape which holds down the bb switch hatch when delivered as removal of tape has taken the paint of both my models.
Has anyone any idea if the battery hold size has changed as my first Tiger hapily held a slightly larger vapex 3700 battery which will not fit my new Tiger as too tight on length. The HL 2000 battery fits ok as it is slightly smaller
Can anyone tell me how to add a photo?
#68
I have a hen long tiger 1, bought in china for around 550 Yuan.
I lost a ton of those plastic things when i let my dad have a shot and he nearly killed it when almost fell of a 3 tier wall [X(] (it only fell by 1 tier )
I thought when i first bought it it would be chinese crap, but since using it i discovered it is quite hardy for the price.
#69
Hey guys, I just got HL's Panzer IV F 1 - pretty cool!
Anyway, I also have their Panzer III, the "programming" version. Can anyone tell me how to use the buttons? The symbols are a broken circle with ok in it, a circle with a diagonal line, and a wiggly line with numbers under it.
(I posted this elsewhere too)
#70
I have a Tiger 1 and a Panzer III (or I will have, as soon as the delivery guy gets his truck into gear).
I'll post a pic of the Tiger when its finished, its not in a state to be shown at the moment
#72
oh alright then
http://s174.photobucket.com/albums/w...t=DSCF8003.jpg
turret is being weathered at the moment, so its a bit messy as I haven't tidied it up yet. The guns being extended but I'm waiting for a new Airsoft barrel before I reassemble that.
#73
BC, CANADA
Yes,
I have a Tamaiya Tiger and I have a question.
How come my Tank commander hasn't got any legs and when I turn on my tank instead of engine sounds it plays german marching music?
Whats a Henny Long is it a drink?
