Heng Long circuit board dimensions (Non-S&S and S&S)
Hey all,
I have two quick questions regarding Heng Long 1/16 tanks:
1. The tank's receiver/circuit board -- what are the physical dimensions of the non-S&S circuit board, and the S&S circuit board? (could someone measure how long and wide it is?)
2. Are the Tiger's internals the same, I mean if you convert non-S&S Tiger 1 to Smoke & Sound, do all the screw holes line up etc?
I have a few projects on the cards (converting older wire-controlled tanks to full-wireless RC) and was hoping for some answers to make planning easier
Thanks in advance!
Thanks in advance!
RE: 2 Questions regarding Heng Long Tiger 1
The very first non-smoke Tigers did not have the attachments and mounts for the smoke and sound gear. Newer tanks do. I do not have any dimensions handy.
Here you are====NON S&S Board--3 1/8 long--2 3/8 wide--aprox--1 inch high---
S&S Boards,there are two of them===Big board--3 in. long--2 1/2 in. wide--little board===2 5/8 in. long--1 3/8
wide--aprox 5/8 in. high. Speaker===2 5/8 long---2 3/8 wide--1 1/4 high. Smoker unit===2 3/8 long---
2 in. wide---1 3/4 in. high------------------Hope this helps you out-------BIGMIG
Many thanks for the answers guys, especially you BIGMIG for going out of your way with the ruler
The final results below, for future reference (in metric and imperial)
NON S&S Board
Circuit board
Length: 3 1/8 (7.9375cm)
Width: 2 3/8 (6.0325cm)
Height: 1 inch (2.54cm)
S&S Boards
Big board
Length: 3 in. (7.62cm)
Width: 2 1/2 in (6.35cm)
Little board
Length: 2 5/8 in. (6.6675cm)
Width: 1 3/8 (3.4925cm)
Height: 5/8 in. (1.5875cm)
Speaker
Length: 2 5/8 (6.6675cm)
Height: 1 1/4 (3.175cm)
Smoker unit
Length: 2 3/8 (6.0325cm)
Width: 2 in. (5.08cm)
Height: 1 3/4 in. (4.445cm)
NON S&S Board
Circuit board
S&S Boards
Big board
Little board
Speaker
Smoker unit
