R22 on the RX18 board?
RE: R22 on the RX18 board?
You know - on my card RX -18 This resistance is the same and there are two red and two gold stripes.
But it is not critical 2.2 or 2.7. Power Dissipation resistance is more critical. So - 2 - 3 Ohm - this is normal
So it would be a good idea to put there a higher wattage resistor? In order to better protect the power transistor Q5?
At first glance - you're right.
But maybe - not really.
These resistors as fuses are current. If the current (the total power consumption) rises more - resistors burn. Motors - will not have time to burn . But transistors - will still burn in any case,
With higher wattage resistor - Motors - will burn too
So basically it would be the other way around: putting a lower wattage resistor will protect both the power transistor and the motors, right? But it would probably burn more often.
None. This is not a good idea. As you said - these resistors will burn even more from working currents.
But in excess these currents - all the same transistors will burn first
And now the big question: what's the wattage of the stock R22? I checked today at a local alectronic shop, and found some that are of the same body lenght but slightly thinner, and others that are much larger (1.5x long, 1.5 thick)
Unfortunately now I have forgotten the table size and wattage resistors. And I can not exactly answer your question.
Ask the store resistor of the same size.
In no case - no more.
If you will be given approximately two times less - take 4 pieces of double the value of resistance. And connect the two pieces in parallel.
Or for first - try - the same body lenght but slightly thinner
AB, CANADA
Replace it with the same resistor. Higher wattage won't hurt, and in this case might be beneficial. I higher wattage resistor still offers the design resistance needed in the circuit. It can handle more current flow though.
