PZIV Drive Sprocket
PZIV Drive Sprocket
Hi guys, pretty new to this hobby, how would I correct the drive sprocket location on my h/l PZIV, how do i do it and what parts would i need?
Deano
Deano
RE: PZIV Drive Sprocket
The sprocket looks like it needs to go back and up by about 8 mm, would i need the low profile stug 3 gearboxes or can the standard ones be made to fit, there doesn't seem to be enough room to move them, how have you guys done it
Deano
Deano
Hi Deano
Easiest way (inexpensive) might be to tilt those gearboxes backwards. That way the front will go higher and little bit back also.
I havent done that yet by myself, but have measured that it could be done. If I remember right, correction with those Stug-gearboxes has been done with success.
Yours,
Red Rabbit
Yours,
Red Rabbit
