Rx-14 board plugs
BC, CANADA
Rx-14 board plugs
Anyone know where to get the connectors/plugs/sockets for Rx-14 boards, or at least know what their model name/designation is?
I'm talking about the 2 wire male ends that go to the motors.
RE: Rx-14 board plugs
Try "JST" type connectors available at a hobby shop. They are not an exact fit but the plug will fit in the socket and the pin pitch is correct. We have all looked for the correct connectors but I guess they are only available in China
CA
Digi-Key P/N 455-2247-ND
Description CONN HEADER XH TOP 2POS 2.5MM
The Blitz
PS Ken after I did some research form telling you it was 2 mm I found out it was 2.5 and have sourced them from Digi-key forgot to tell you![:-]
The Blitz
BC, CANADA
I found one in a hand crank flashlight, but my local hobby shop was next to useless and looked at them like they were from another planet. I had considered getting 2 speaker units from Mato and using the plugs.
Thanks for your help.
ORIGINAL: smittyrob
2 pin and 3 pin connectors
CA
ORIGINAL: RCCOMMAND
You mean these...
ORIGINAL: smittyrob
I'll take 50 of the 2 pin and 25 of the 3 pin! Serious!
The Blitz
BC, CANADA
So you can get 100 male plugs at Digi-key for $4.06 and then you just need the crimp connectors 100 for $3.18.
More than I'd hope you would ever need.....then again...
ORIGINAL: smittyrob
Yep, those are the ones, I didn't see those on your website.
Ahhh, now I do, thanks Bill
You mean these...
Bill
CA
ORIGINAL: smittyrob
The blitz
