Reload this Page >
M4 SHERMAN DOZER RC... in action!
Old 01-04-2009, 04:27 AM
borealis
borealis's Avatar
Default M4 SHERMAN DOZER RC... in action!
These pics were sent to me from a member of my rc tank club.
It's a Tamiya Sherman equipped with a working dozer blade.
The blade can be moved up and down, and can be used to clean your terrace from snow
I have asked for a video too, hope he will find the time to shoot one.
In the meanwhile, enjoy some pics
ID:	1103061   Click image for larger version
ID:	1103062   Click image for larger version
ID:	1103063   Click image for larger version
ID:	1103064   Click image for larger version
ID:	1103065   Click image for larger version
Jean_Pierre (11-02-2021)
Old 01-04-2009, 06:08 AM
SoulAssassin
SoulAssassin's Avatar
Default RE: M4 SHERMAN DOZER RC... in action!
That is really cool! Love the paint job also.[sm=thumbup.gif]
Old 01-04-2009, 08:00 AM
pattoncommander
pattoncommander's Avatar
That is a very fine model. Very realistic and great weathering and battle damage. That's what a combat vehicle should lookl like. [sm=thumbs_up.gif]
Old 01-04-2009, 08:10 AM
Dongskie
Dongskie's Avatar
Video!! Video!! Video!! Video!!
Old 01-04-2009, 09:56 AM
YHR
YHR's Avatar
I really like that. I was thinking of doing the same thing. I was going to use the cannon bbl to lift the blade though. I wonder how this guy gets the blade to go up and down???? It is not clear to me in the pictures.
Old 01-04-2009, 10:46 AM
Panther F
Panther F's Avatar
WOW!! I really love it and it works too! This looks like it came straight from a WWII photograph!
Thanks for sharing!
Old 01-04-2009, 10:51 AM
Panther F
Panther F's Avatar
ORIGINAL: YHR
The number 2 photo shows wiring coming out near the mounting at the second suspension unit, probably going to that actuator in the number 1 photo. Pretty slick set up.
Old 01-04-2009, 11:03 AM
thomasjohnmurphy
You don't much better than this. I'm impressed.
Old 01-04-2009, 12:36 PM
StumpyBloke
StumpyBloke's Avatar
All I can say is.... AWESOME!!!!!
Rich
Old 01-04-2009, 01:31 PM
googlydoogly
that looks freakin' great!
Old 01-04-2009, 01:40 PM
blitzkrieg65
blitzkrieg65's Avatar
The only thing cooler would be to see some video of it![sm=shades_smile.gif]
Old 01-05-2009, 12:31 PM
borealis
borealis's Avatar
A technical description directly from Luca, the builder:
The “ M4/105 Dozer “ has been an own made upgrade with a bulldozer basically made by Al / copper and plastic card machined using just simple tools ( NO automatic milling cutter or lathe ) like drill and sandpaper etc... but with very high level accurate details .
The automatism was created using a standard Tamiya planetary gearbox set which pulls up and down a mechanical piston through a stainless steel wire ; the entire mechanism is mounted inside the tank and only the wire pass through the bottom of the tank as in the realistic actions.
The RC command has been done using the turret control stick which is switched ( used a RC micro SW ) to a simple speed controller which drives the planetary gearbox motor , so a 5 CH radio is needed
I’m available for further details
Kind regards
luca
Old 01-06-2009, 01:08 PM
borealis
borealis's Avatar
And finally a short video of it
http://www.youtube.com/watch?v=5LnHIrsvtn8
Old 01-06-2009, 01:44 PM
Panther F
Panther F's Avatar
SWEET!!!
Old 01-06-2009, 04:38 PM
philipat
Very cool...but the video was way too short. More snow pushing!
Old 01-07-2009, 11:15 AM
Dmon1996
Dmon1996's Avatar
Actually, I'd like to see that Sherman pushing a burned out Tiger off a dirt road, but this was neat too.
One thing though....I think the blade needs far more weathering judging from the wear and tear evident on the tank itself - these tanks were used to push off wrecked tanks and other equipment. That abuse should be evident more on the blade surface- I think there would be almost no paint left, only bare metal. Of course, I don't know if the crew for one of these tanks would paint the blade periodically so as to not give away position from a light flash on bare metal.
But that is just my opinion, and that's only because I have to find some flaw - I am so jealous of this tanker's skill in fabricating such a great working variation!
Old 01-08-2009, 09:26 PM
Rambeast
Rambeast's Avatar
OMG!!! I want one I want one I want one! Great job [sm=tongue_smile.gif][sm=thumbup.gif]
Old 01-09-2009, 08:53 AM
heavyaslead
heavyaslead's Avatar
Nice, very nice.
Wonder if the planetary drive for the blade is strong enough to lift the front end of the tank?
Get some winter tracks and it would truely be awesome!
Old 01-09-2009, 09:56 AM
pattoncommander
The dozer blade will not reflect any real damage unless the lower edge happens to "locate" a mine. This would normally just take a chunk out of the bottom. The blade at that point is a good 6-8 iches thick and very tough. (The dozer and mech on the M-48 weighed nearly 4 tons.) The dozer is painted as much as needed to keep it from becoming a mirror , but the lower portion will nearly always be clear of any paint and looking clean. Here's my dozer In "Camp" Irwin Ca 1959
Old 01-09-2009, 07:06 PM
borealis
borealis's Avatar
ORIGINAL: heavyaslead
I was told so by the builder
Old 07-15-2012, 04:47 PM
blazer85
Hi, Just saw the pic & vid of dozer tank. I'm building the 1/16th M4 sherman & would like to know If Ur fiend has plans , material list for building the dozer attachment will pay for them.
Thank u
Richard
Old 07-16-2012, 03:35 AM
borealis
borealis's Avatar
Nope, sorry, and hes no more in my tank club.
Old 07-16-2012, 04:55 AM
CCC2012
Banned
beauitfuil!!!!!!!
Old 07-17-2012, 09:32 AM
flamme
Look at this one...my tank dozer
http://www.youtube.com/watch?feature...&v=g5VXqE2-b-k
Old 07-17-2012, 09:43 AM
flamme
here you buy the system
http://rc-panzer.*****.com/t5212-SAU...ITION-2012.htm
You need too this one. I don't know how to say it, but when you use it it cut automaticaly the run in both side when it detect the final course. Hope you understand
http://www.tecnimodel.com/modules-el...thor2-678.html
