Wiring diagram for HL RX18 Board
Reply
Old 01-08-2009, 08:47 AM
Alan123
Alan123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wiring diagram for HL RX18 Board
Has anyone done a diagram or photo guide of how one connects the new HL RX18 board into a HL tank that did not have one before.
I am trying to do one at the moment and am having trouble working it all out and really need a guide for dummies because I am no good at this sort of thing at all and am likely to damage something.
It is the turret connections that are hard to work out, especially when one has a recoil unit installed.
I need to know which wire goes where.
Alan.
Alan123 is offline
Old 01-08-2009, 09:17 AM
YHR
YHR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Wiring diagram for HL RX18 Board
Here you go
[link=http://darkith.dyndns.org/~darkith/html/rx18.shtml]RX 18[/link]
YHR is offline
j z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Alan. Atkliev had a similar post and bubbajoexx posted a pretty detailed photo diagram of what all the outputs are for. Look for upgrading to rx-18. Regards, JZ
j z is offline
Old 01-08-2009, 11:06 AM
Alan123
Alan123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is exactly what I needed. It even has notes for connecting the Tamiya things.
Alan.
Alan123 is offline
Old 01-08-2009, 12:30 PM
Alan123
Alan123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well the diagram could not have been that good as I have connected the turret turn and elevation units, powered on for a test and the RX18 smoked and is now no good. Thats $30 straight down the toilet. F'ken great!
Alan123 is offline
Old 01-08-2009, 01:22 PM
darkith
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hrm,
Most of the diagram is correct, as it looks like it was mostly cribbed from the one I drew up, and I'm pretty sure of the information I traced out myself.
The turret and elevation wasn't on my diagram, and I see what looks like two errors, one in the speaker volume port, and another for the turret info. Should be one wire for elevation, one wire for fire (airsoft or recoil), and a common B+ wire for elevation and fire.
Based on other diagrams, I think it might be:
C: Elevate (switched negative)
D: Fire (switched negative)
E: Elevate & Fire (B+)
Though, I wouldn't have thought that that error would cause the board to smoke. Another possibility is the the key is backwards (e.g. A & H are backwards, B & G are backwards), which could have toasted the 5v regulator on the board from excessive current draw.
D.
darkith is offline
Old 01-08-2009, 01:55 PM
Alan123
Alan123's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
God is with me! After cup of tea and a rest I went back to my setup and the board must have somehow recovered as it now works again, but with that much smoke it can never be 100% of what it was.
Whats more I worked out where the error is. On turret elevation you have to use pin 3 and 5 (just like with an Elmod conversion which is what made me think of it), thats Blue D and E on the diagram not C and D as shown. I think you cover that in your last reply.
Pls do not be disheartened, the diagram is great and thanks a lot for producing it.
Any idea where to put the 2 wires that come off the Asiatam Recoil unit?
Cheers
Alan.
Alan123 is offline
Old 01-08-2009, 03:20 PM
j z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to hear your board is O.K. I was feeling sick to my stomach, I know all to well what it's like to finally have a new board arrive , only to have it detonate . Good luck . Regards, JZ
j z is offline
Old 01-08-2009, 11:58 PM
swathdiver
swathdiver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: j z
That's why you always buy 2! I was beginning to think with these great 14 and 18 boards it was ok to change my signature, looks like I'm going to change it back!
swathdiver is offline
Old 01-09-2009, 04:41 PM
j z
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used to order many at a time. Then as I learned a little more, I must have gotten over confident with myself. These newer boards are almost fool proof, but until they make them idiot proof,I have to be on my guard. No James, I don't have spare boards. Regards, JZ
j z is offline
Old 01-09-2009, 06:47 PM
bubbajoexx
bubbajoexx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
UPDATED DIAGRAM
bubbajoexx is offline
Old 01-09-2009, 08:30 PM
YHR
YHR's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: j z
Funny
I always have spare boards. Not because they Heng Long board are bad, more just because I am so stupid
YHR is offline
Old 01-10-2009, 08:18 AM
philipat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm comparing the colored letter diagram and the one on Darkith's webpage and I have a couple of questions about the RX-18 board:
1) Where does the smoker switch go? Is it still integrated into the board like on the 13 and 14 boards? Or is that the green A/B? The Red A/B looks like the leads to the smoker itself. I don't think it's the main on/off switch because that goes on the positive lead between the battery and the board (sits between the light blue A/B).
2) If you order the RX-18 separately, does it come with the volume knob terminated in the correct plug? How about the smoker switch and power switch? I guess the latter two could be done with the jumpers that RC Command sells.
philipat is offline
Old 01-10-2009, 09:46 AM
bubbajoexx
bubbajoexx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lime green a and b are the smoke switch the power switch is the one used on the original tank location
Reply
Display Modes
