Which HL motor is faster?
Which Heng Long motor is faster than which?
Tiger motor with white end-bell:
Bulldong motor with black endbell:
So which is faster?
So which is faster?
RE: Which HL motor is faster?
ORIGINAL: swathdiver
11000 white, 16500 black.
looks like i'll be moving the M41A3 motor into the Tiger and my M41A3 takes the new pair of Graupner 400... or the Panzer 3 takes the Graupners?
thanks guys!
If you search for our posts on motor and gearbox testing, the black capped motors in a Tiger will allow it to run about 2.5mph, much faster then stock!
The Graupner Speed400s in the BullDog will give you about 2.1mph
The PZIII runs at about scale speed with the white capped motors, 1.6mph.
These are the scale speeds.
M26A1 Pershing
40km h = 25mph 1.56
Tiger I Tank
38km h = 24mph 1.5
M41A3 Walker BullDog
72km h = 45mph 2.81
Panther Tank
55km h = 34.18mph 2.14
Panzer III
40km h = 24.85mph 1.55
T-34/85
M18 Buick Hellcat
55mph = 3.44mph 3.44
Panzer IV Ausf G
42kmh = 26.1mph 1.63
M4A1(76)W
Sustained 34kmh = 21mph 1.31
Dash 39kmh = 29mph 1.81
M26A1 Pershing
40km h = 25mph 1.56
Tiger I Tank
38km h = 24mph 1.5
72km h = 45mph 2.81
Panther Tank
Panzer III
T-34/85
M18 Buick Hellcat
Panzer IV Ausf G
M4A1(76)W
Any body have a good source for the Graupner Speed 400's, not the big block 480's. i want to try these with the new speed reducers from RC4WD that we've been talking about.
ORIGINAL: Panther G
I only got one motor from www.modelflight.com.au which wa their last stock, so I had to order another motor from www.hobbylobby.com
Hobby Lobby charge $25.00 US for international shippin aside from the postage &handling (bummer!)
And they arrived at the exact same day..
Good luck!
Oh Swathdriver, btw it means that the Graupner 400 is just about the same as the HL black endbell motor?
Th No-Load speed of the Graupner 400 is 16400rpm
HobbyLobby is the distributor in the USA.
Dongskie: They're about the same but not quite. The Speed400s are slightly more powerful and have more torque.
ON, CANADA
yes. I noticed they had less of a draw (amps) than the 6V I didn't want to blow the board (I'm not that knowledgeable about electronics so I hope I got the right motor)
Just a reminder fellas, don't forget to address cooling your boards. I'm not up to date on the 18 but the 13 needs a fan to keep it cool when running the Speed400s. In Perry's case, the higher reduction gears lessons the load on the motors as I also experienced running 480s with El Mod.
Not too small.....James makes reference to gear pullers like these:
http://www3.towerhobbies.com/cgi-bin...?&I=LXHHN3&P=0
for shaft diameters ranging from 2.0mm to 3.2mm
Regards
Jose
Regards
Jose
thanks for the tips guys!
Since a small puller is hard to find, I made one myself from a few nuts and bolts and 6 pieces of nitro car brake calipers:
