heng long troubleshootin
Reply
Old 04-30-2009, 09:41 AM
afmatt130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default heng long troubleshootin
hello fellow tankers!! recently purchased the heng long panzer 3 from matomart.com. it has the metal upgrades, gearbox, tracks, etc. after less than one hour of run time the gun barrel started to cycle continuosly. then the turret started to rotate on its own. with the transmitter off and battery on, it does it, so i know ive eliminated the transmitter as the problem. i unplugged the wires for turret function...the tank still drives well though. any ideas?? im thinkin something took a dump in the circuit board...ive heard these boards are fairly flimsy. does anyone make an upgraded board with quality electronics on it...or am i stuck replacing it with more stock heng long hit or miss boards?? thanks for your help
afmatt130 is offline
Old 04-30-2009, 10:04 AM
ssrc30
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: heng long troubleshootin
ORIGINAL: afmatt130
You might wanna try upgrading to the RX-18 board. It's more durable than the 14 which is what you likely have now. MatoToys sells them and so does RC Command.
ssrc30 is offline
Old 04-30-2009, 10:11 AM
thomasjohnmurphy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the question I have is can the RX18 board be used in an airsoft application? If so how do you eliminate the tank jerking when you up the right up stick?
thomasjohnmurphy is offline
Old 04-30-2009, 10:35 AM
afmatt130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks ssrc........can i keep the airsoft application with the rx18 board?
Old 04-30-2009, 12:42 PM
thomastk
thomastk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hallo new to the forum try the antenna take the top of and check the antenna connektion inside i had the same problem whith my tiger 1
thomastk is offline
Old 04-30-2009, 01:46 PM
afmatt130
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
had the tank apart...antenna connection was good. im pretty sure that whatever controls turret function in the board probably fried. does anyone know what would be involved in converting the electronics over to tamiya?
Old 04-30-2009, 05:08 PM
thebronze
thebronze's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: afmatt130
thebronze is offline
Old 04-30-2009, 05:26 PM
blitzkrieg65
blitzkrieg65's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: afmatt130
Or you can upgrade to EL MOD..... The tank below still uses the HL elctronics and radio, but you do not have too that is just an option, EL MOD actually perfroms best when you pull all the HL eletronics and use a Hobby radio! Plus the sounds go way beyond Tamiya..........
http://www.youtube.com/user/RCTankWars
The Blitz
blitzkrieg65 is offline
Old 05-01-2009, 07:04 AM
thomastk
thomastk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmm freid bord sems to be happining a lot i installt acpu fan connectet to the power cords this cool things i usually run the tank for a long time (35000 milliamps)
this works[8D]
thomastk is offline
Contact Us Archive Advertising Cookie Policy
