- PANTHER ONLY PICTURE THREAD !
#31
RE: - PANTHER ONLY PICTURE THREAD !
Hi guys,
Okay, here are some pickies of my heavily modified HL panther to a more reasonable lookingpanther A.
this thing weighs a ton with all the metalwork on it but it drives okay and the BB gun is quite good.
Cheers
CaptB
#33
well here's my HL Panther G
i may have too much black on it i used a piece of styrene for the headlight cover, piece of plastic for the radio antenna, some styrene for the side armour, not too sure if my hangers are going to make it have to find something better ,still have a bit of touch up
#35
I like the wintertime paint schemes. Looks good!
- Jeff
- Jeff
#36
Here are my 1/35th scale G with early mantlet and 1/25th A.
I swapped the 1/35th scale turret turn and elevation system into the 1/25th scale model, bit
tricky lining up the turret ring but worked out well.
#37
Also found some pic's of my 1/25th Panthers all three versions. I scratch built a
Bergepanther platform and made it so I could swap the it with the original turret.
Two tanks in one, no spade or winch as this is a tow vehicle as well as fuel and
ammo supply. I have had the Berge tow the Jag, even with the tracks locked!
#38
ORIGINAL: peterphillipps
nice tanks
#40
Very good work. Looks great. Must be something in the water that you drink to make you a lot better than average.
