Jagdtiger Tamiya 1/16
Any thoughts how you can build the cannonholder for this beast so when use the jagdpanther recoil unit of tamiya with several FO uses so the canon acts like the real one
RE: Jagdtiger Tamiya 1/16
It's got a Tamiya King Tiger Recoil assembly installed, mounted with the Tamiya King Tiger recoil stay. As for the trunnion assembly, I used the trunnion out of Tamiya's Jagdpanther kit, and mounted it on two aluminum plates that I fabricated out of some aluminum stock. The servos were some leftovers from a Spektrum Dx6 radio I had. I used camera positioner switches from Dionysis Design to slow the servo speed to a crawl, and to hold the servos in place when the tx sticks went back to the center position. I wired up the servo's using the information from H.E.A.T. 's (tank club here in the US) website.
It is pretty durable. I've been battling it about 1 1/2 years now, with no malfunctions or breakdowns.
Here is the Wecohe Jagdtiger main gun system. It uses the Taimya Tiger 1 recoild system, and this one has been modified with the Wecohe prototypical recoil system. The recoil system takes a little work to make it correct in that all the parts must line very straight so the unit will not bind.
he robert can you give the link of your tread of the wecohe jagdtiger you made ?
have a few holland guy's wich were interested to see the wecohe one
thanks
here is the link to the holland guy he is busy with one ... but its in flemish : http://ossekopfdivisie.forum2go.nl/j...ybrid-t12.html
thanks
LOL You beat me to the punch. Got up an hour ago and still wading through emails and such when I decided to look at RCU. Thanks for posting the link!
Bob
Bob
would be great if tamiya must do that , would counter almost all wrong JT models that came out ... would there no marked fore anyway guy's ???
ORIGINAL: karel47
Sad thing is these are only our dreams.
