Alternatives To HL Turret Elevation?
Reply
Old 02-06-2010, 07:15 PM
BiggTony
BiggTony's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Alternatives To HL Turret Elevation?
Alrighty, it's apparent that I am poor at planning ahead. I'm in the process of converting my Tiger I into the initial production 502 spzabt. Got my stowage bins nearly complete, already began the process of removing the mud guards.........then absolutely forgot that a portion of the elevation unit is housed in the factory stowage bin. Epic failure. Good thing I haven't started cutting the stowage bin out.
Anyone with solutions to either repositioning or fabricating an alternative elevation unit that doesn't need to be partially housed in the factory stowage bin?
BiggTony is offline
Old 02-06-2010, 07:48 PM
gorehound
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Alternatives To HL Turret Elevation?
Hi
The Panther G, Jagdpanther and Stug III all use a side mounting elevation unit simlar to the Tamiya one (and in my use a lot stronger than the Tamiya one). You could use this and mounting it would not be too much of an issue. Mato, rccommand and various other sellers have them listed.
Hope this helps
Gorehound
gorehound is offline
Old 02-06-2010, 09:25 PM
BiggTony
BiggTony's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks alot gorehound,
Does the elevation unit need any other mechanism to be attached to the airsoft unit other than the swing arm that's already attached to the elevation unit?
Anyone happen to have pictures of this elevation unit attached to the airsoft unit?
BiggTony is offline
Old 02-06-2010, 09:49 PM
Ern
Ern's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's a pic of the elevation unit on the Panther G... the tan piece rotates inside of the black piece attached to the side of the airsoft gun...
ID:	1373379   Click image for larger version
Ern is offline
Old 02-06-2010, 10:11 PM
BiggTony
BiggTony's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ern thanks a whole heap!
My mind is still trying to wrap around the idea of that arm rotating within that bracket. But, I'll see if Phil has that unit with it attached.
Thanks again!
BiggTony is offline
Old 02-07-2010, 03:32 AM
khatean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Panther G component selection sounds like good advice. I am actually doing the same thing with my son's Tiger 1. I am converting to recoil using a spare I ordered from Mato along with the side mount elevation unit used in the Panther G. A custom early mantle, barrel, muzzle, recoil interface and true Tiger 1 gun trunions should do it. I hope.
khatean is offline
Old 02-07-2010, 07:41 AM
Saxondog
Saxondog's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Ern,since I have not cracked open my Jagdpanther can I assume it has the same elevation unit as The Panther-g ?  And on another note Sarah was in Nashville this weekend.Supper,fantastic,lady.
Saxondog is offline
Old 02-07-2010, 11:01 AM
Ern
Ern's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: gorehound
Hi
Looks like the Jagd has it too Sax... [sm=thumbs_up.gif] for SP in Nashville!
Ern is offline
Old 02-07-2010, 01:11 PM
gorehound
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry, the Jagd does not have it as standard - my mistake. I converted my one to use the side mounting one though as it worked better for what I was trying to do.
cheers
Gorehound
Old 03-20-2010, 05:51 PM
BiggTony
BiggTony's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AAAARRRRGGGGHHHHH!!!!!
I have the channel made, but it's not strong enough to elevate and lower it. The gears keep trying to strip.
Anyone who has modified their tiger to use this elevation unit. Please give me some help!
BiggTony is offline
Old 03-20-2010, 06:49 PM
yellowshaker
yellowshaker's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Howabout the asiatam recoil unit?
yellowshaker is offline
Old 03-20-2010, 06:57 PM
BiggTony
BiggTony's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, not quite ready to make that transition into ir/recoil units. I'm the lonesome tanker here in these parts. so I'd like to keep the airsoft unit for now.
I think I'm doing something wrong. Either the channel is too wide or too high. Same with the elevation unit.
The think is, since I've hacked that stowage bin off, this reduces the length of the turret and the area which used to house the old elevation unit.
The placement requires the new elevation unit to be a little closer to the front, decreasing leverage and increasing resistance.
I'm not sure if the the tanks that use the side elevation unit still utilize the counter spring that keep the airsoft unit pressed up. This is what is causing some serious resistance.
I've made a smaller tight fitting channel that the arm can glide through without the need for a spring, but now this requires me to mount the elevation unit higher.....therefore making it impossible for me to screw the bottom of the turret on.
Obviously there must be a G spot on this baby and I need the virgins guide to find it!
BiggTony is offline
Old 03-20-2010, 08:01 PM
BiggTony
BiggTony's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Come on.....I'm seeing some master builders and geniuses viewing this thread!!! Don't leave without solution!!! lol
Don't turn your back on me..........."I got no where else to go! I got no where else to gooooOOOOO" ~ An Officer AndA Gentleman
Haven't been gettin much sleep!
Edit: This would probably be most helpful. The distance the side elevation unit should be height and length from a determined area of the airsoft of HL recoil unit. What type of mounting bracket for the elevation unit as well.
BiggTony is offline
Old 03-20-2010, 09:47 PM
Panther G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just gutted my HL Pershing and started another Tamlong conversion. Got the gun recoil and mantlet assembly all done. just not sure how i want to use for elevation. i could go the safe route and just spend the cash for a Tamiya elevation unit but the turret designs are quite different between the Tamiya and HL. Been considering a mini servo set up. Any one have any expierience with this mod?
Panther G is offline
Old 03-21-2010, 07:15 AM
cheap tank
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try a servo take the guts out remove the stops and it makes a powerful little gearbox. I have used in a couple tanks including my tiger and traverse on my jagdpanther. I have tried using a servo arm and rod like a standerd app or use a cam and spring.
cheap tank is offline
Contact Us Archive Advertising Cookie Policy
