what size is a rx-18 board lgth x wdth x hght
RE: what size is a rx-18 board lgth x wdth x hght
Without the casing-
2.431 x2.006 x 0.665 (highest points)inches
With the casing-
2.550 x 2.165 x 0.833 inches
With the casing-
No problemo!
What scale are you making the Stuart?
The rx18 and the receiver (if your using the HL receiver) aren't very large at all as you can tell by the dimensions for the RX18 board. You could probably fit this in a 1/35 scale tank( tight fit though)......not sure about a 1/35 scale Stuart though...but definitely a tiger.
I am making it in 1/16 scale( but as you can see from my other posts) I am also creating these in a computor cad system (UGNX 6)
This will allow me to make drawings in any scale needed.
ORIGINAL: dedmonwakin
No problemo!
No problemo!
