Panther G Side Skirts
Have a Buddy who wants to add skirts to his HL Panther. Anyone know where he might be able to get these?
He is brand new at this. Met him at the hobby shop. Tryingto get him to come on board here.
Thanks Brothers
Don
Thanks Brothers
Don
RE: Panther G Side Skirts
I don't know if this would help him come on board......pretty pricey for what styrene or K&S brass sheets can do....but,
http://etoarmour.com/product_detail....ductID=AB16018
http://www.wecohe.de/shop/index.php?...roducts_id=228
http://www.welshdragonmodels.co.uk/p...ale-1209-p.asp
http://www.tank-modellbau.de/
You can alway try going direct to Aber and seeing if the cost would be less..........but if it's like anything else, manufactures often times charge more than the retailers....not sure how that works sometimes. lol
http://aber.net.pl/detal/bay/panther...rts_053215719/
Let me know Don and I'll find the measurements for you. I work with styrene ALL the time and cutting these out would be child's play for either of you.
That is, if he doesn't want the PE set.
- Jeff
- Jeff
I did the PE set watch out the hangers are not that good ended up making my own .
jimmy
jimmy
You know Jeff you are right. Send methe diminsions and I'll assist him in making his own. That is the only way we learn.
Thanks Brothers
Don
Thanks Brothers
Don
Made mine out of metal sheet, made up brackets out of square brass rod, soldered, pushed, prodded, pulled, bent, dented, scratched and put in water, best way to simulate rust is have the real stuff
ORIGINAL: torpedochief
Thanks Brothers
Don
Thanks Brothers
Don
Don an Jeff,
Can you share the dimensions with us ?
Thanks.
Jim
tHE pe ONES ARE A TAD TOO WIDE FROM TOP TOO BOTTOM. i HAD THEM ON MINE BUT THEY JUST DID NOT LOOK RIGHT. tHEY CAME DOWN PAST THE TOP OF THE ROAD WHEELS. MOST PICS. i'VE SEEN THEY ENDED JUST ABOVE THE WHEELS. tHEY ARE VERY EASY TO MAKE. I MADE A SET FROM SHEETY METAL, OR YOU CNA USE STYRENE.
ORIGINAL: 1sgt
Don an Jeff,
Thanks.
Jim
Thanks Brothers
Don
Thanks Brothers
Don
Don an Jeff,
Thanks.
Jim
- Jeff
