1/16 scale heng long tank
I got a heng long tank off ebay for £30 its amazing, untill when takeing it through the peble pit then it got a chip from a willy jeep driveing past it smashing all the pebles into it. Now it has a chip on the body and a crack. Now i want to fill it in and re paint it, what should i use? i want to spend max £5 on it.
RE: 1/16 scale heng long tank
Before you apply body filler use some CA glue (krazy Glue or what ever you call it in England) in the crack and in some cases the glue could be used as filler as well, then you treat it like any time you would glue plastic together, filler, sand smooth and then prime and then paint. Easy stuff.
A technique I have used for cracks is to drill each side of the crack to keep it from getting bigger.
Then I use a#11 blade to scape the sides of the crack into a V shape. Then apply a bead of CA and sprinkle that with some baking soda. Repeat as needed, then sand and finish.
Hope that helps!
Don
Hope that helps!
Don
I have never heard of using baking soda acts as a filler does it? The drilling ofa hole makeassense. You could also usesolvent cement that will weld the plastic together an then CA and baking soda.
