Smoker doesn't work
WA
Smoker doesn't work
Hi All,
I received my HL Panzer lV f2 last week. Everything works well except the smoker. Does anybody have a fix for that? I understand it’s a common problem.
Perry
RE: Smoker doesn't work
could be to much liquid in it than it would not smoke, i could be broke to but not likely because its new, but don't expect too much of it
I agree, it is a common problem.........but I think it's wrong of you to suggest that only smokers don't work......non-smokers don't work either! Finding afix allsolution for laziness isn't easy though! Let me know when you found the cure!
The fix that seems to be the most popular and reliable is to VERY carefully remove the smoker from the tank and then go outside and throw it on the concrete as HARD as you can................Its happened on all three of my HL's and it solved the problem every time! Smokers look fake anyways(until they can produce black smoke) and just make a mess...not worth the hassle in my opinion.... RCCommand has some nice upgraded style smokers but they still produce that lame white smoke...http://www.rccommand.com/Whats_new.php
non its quite easy you just have replace the resistance of 20 ohm i placed a 120ohn instead works better now
wrong panther my smoke-unit still smokes at my panther not much but enough, my jp has a 120 ohm resistance in much better
