8ight t 2.0 454 rtr pipe
NM
Is the stock pipe a losi ht ? And for racing would it be better to run the 053. Looking for a bit more on mid to high. And longer run times thanks
RE: 8ight t 2.0 454 rtr pipe
The stock pipe is great for mid to high - especially with an OS A5/#10 plug.
I have heard people say try an 053, but when I tried one on my Mach 427(SH 26, very similar to the Losi, which is an SH 28) it was horrible - zero top-end..
For racing, a JP-4 is probably a good call for the Losi. Will tame it a bit, and save you run-time..
For all-out power though, the stock Losi pipe is very good. It's just underrated for big-block engines because people think you automatically have to go uprgrade everything on an RTR. Not so in the case of the Losi HT pipe..
Yes it's an HT pipe, and no I wouldn't bother with the turbo conversion. If you're racing, spend your money elsewhere - servos, tires, etc..
ORIGINAL: HerrSavage
053 is good for 28 because it is torque, tames it... JP-4 is good also.
I think a lot of people though would say that a standard 28 is already too much torque, and so will just lead to unproductive wheel-spin. Even if the turbo-conversion really does make much difference(which I'm skeptical of.. But who knows?..), for a light-ish truggy like the 8T, that would just mean MORE wheel-spin right?..
IMO the 8T 2.0 RTR is a great buy. But the first thing I would buy would be servos - and good servos aren't cheap.. If you've got the 20 bucks to burn after servos, sure, go ahead and try it.. But I personally wouldn't put it very high on the priority list.. Racing entails all kinds of other expenses just to participate. A turbo-head is just an unnecessary option IMO..
And my thinking on pipes would be, the 28 has plenty of torque, so better get a pipe for top-end.. But why put a torque pipe on a torque engine(unless you're pulling or climbing..)? A .28 in truggy will have enough torque with most pipes..
Again, the best tip for top-end IMO is an OS A5 plug.
NM
Ya that's what i was thinking i think i will go for a top end pipe what would u run
For all-out power on an LRP Spec 3/Losi 454, in my experience the best pipe is a JP-2. For racing, I would tone down the power in favor of run-time, and go with a JP-4. There are surely other good pipes. I would recommend something used on ebay. JP-4, JP-2, 2047, probably a Losi RE10, or just stick with the stock HT pipe. Again, with the RTR, it's all about SERVOS first and foremost...
HT stands for High Torque...
the 053 will smooth out power. JP-4 will also... RE10 will do the opposite. ... the 086 is a top end pipe, might be your best bet. or if you want to spend about 85-90 bucks, the Alpha 2090 would be a good pipe to smooth out the power, and still make it stout.
but servos are a MUST for RTRs, so i agree with spending money there first.
The Losi HT type, "high torque" or not, has more top end IMO than torque. Have them on two LST2's and have raced an HT (stock Muggy) pipe in buggy and a couple truggies, and they definitely let the engines wind out more on top than give them like stump-pulling torque or anything. With a Mach 427 and the HT pipe I was even getting 10 minutes in truggy.. Key to top end in these SH engines is an OS A5 plug too.
I realize now though that the performance of those engines was somewhat skewed because I was running a well-used Fioroni slider clutch - zero maintenance, which is great.., but I suspect it made things way too soft on the low end.. For bashing though, awesome clutch.. 10 gallons + with pretty much just changing the bearings every couple gallons..
To the OP, have you even run the stock engine and pipe yet? If not, I would say just try it and see how it goes.. Unless you're racing at a pretty high level, I really don't think investing in a pipe is gonna make a big difference. Again, servos and tires, servos and tires.. AND SETUP. And a good clutch is also very important..
The 2090 pipes here funnily enough are cheap.. Jmaxey, are they really that good? I want something for my Argus(Alpha S852 more or less..), and everybody says get the 0801 - but they're not available here.. The 2090 I can get locally for €60(most pipes cost €80+... I could get an 0801 from Austria I think, for €95.. Paid €110 shipped for the Argus.. Or, order from abroad, wait while it goes to Customs, etc..) They (the 2090) don't seem to have caught on much yet.. I also care much more about power than run-time.. So far I'm not too impressed with the JP-4 on it, or now the 2063 that I tested last weekend(though generally I love this pipe...)
ORIGINAL: colossus281
Where can I buy the Alpha 2090
NM
Thanks I still need to get 1 more servo some better tires then i will probably get the pipe i will you guys know how it runs
