RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Official HPI Hellfire Thread
Reply
Old 02-04-2010, 07:42 PM
  #1951
stussman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official HPI Hellfire Thread
The old "my hellfire turns like a bus" comment. Mine turns like a whale not a bus.
The servo horn hitting the servo, one of the many hellfire issues. Most can be fixed tho, with patience.
stussman is offline
Old 02-04-2010, 09:38 PM
  #1952
supertib
supertib's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: stussman
Quote:
ORIGINAL: supertib
with the right engine a Hellfire will wheely.....
http://video.google.ca/videoplay?doc...5989159158821#
Thats an oldy of yours!
I know its aples to oranges comparing that 427 to my os 28 but my modded os 28 is way more impressive than that. I had to decide between one of your modded piccos or one of colts but choose a massive mod due to their location in australia. Ive only got 2 lts thru it but its definately nasty. It really revs out on an 086 to. I tried taking some internal shots to post but my cam is no good. I hope to borrow a cam so i can post a vid and pics within soon.
I do enjoy your vids
that is a very old video !!!! And by no means is that Mach a powerhouse by todays standards LOL !! Yet even still it was wheelying that Hellfire pretty decently...sometimes if an engine has too much power it will not wheely, it will just spin the tires instead..... I actually get more wheelies with a modified .21 then I do with a modified .28, the .21 seems to be able to plant more power to the ground then the .28's.... the .28's just overpower the tires ..... you need traction to wheely......
I would be hard pressed to make a modified Mach 427 even keep up to a stock OS 28... as you say its apples to oranges, a RTR engine vs one of the most powerful .28's ever built........
supertib is offline
Old 02-04-2010, 11:35 PM
  #1953
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mcrazy glad you are coming home safe. What happened to the videos of that track though?
As far as the wheelies go I think he was referring to wheeling from a stand still. My MT2 with the OS TZ in it will wheelie down the block if it hits the slightest bump but not from a stop.
The weather here has been horrible for too long. I cant wait to get my stuff out and do some driving.
KeithjV is offline
Old 02-05-2010, 02:52 PM
  #1954
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Hellfire seemed to turn pretty well when I was trying it..then again it has an upgraded high torque all metal gear steering servo, every HPI I've owned required a new steering servo though, the stock ones are just so weak.
RPaulG87 is offline
Old 02-05-2010, 10:52 PM
  #1955
K-man 15
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the replies but it will be a while before i can see if this is the problem because where i live there is snow, and i asked you now because I just remembered that I had a problem with it.
I have had to replace the steering servo already and it is a JR650M, so could the servo horn hitting the servo still be the problem?
K-man 15 is offline
Old 02-06-2010, 02:09 AM
  #1956
nitroexpress
nitroexpress's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check it out with your peepers. Obviously one side is different than the other. Check for binding or (#1 choice) blockage. I'm sure your powers of observation will notice the difference.
nitroexpress is offline
Old 02-06-2010, 03:22 AM
  #1957
gtr
gtr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 3130pembroke
use hot bodies brake outdrive cups- way stronger I had to machine them down a near the base, seemed to bind a little when the top plate was tightened down
You can get a whole center diff complete for $20 off ebay from a HB D8T- also the HB D8t 101 mm drive shaft assembly work also in the rear, much lighter. I use them on the front also with the Xray xtra long outdrive cups.
If anyone gives a crap I have been running vspec .21 with a HB D8T 13 clutch and 50T spur- Even with the extra weight of this truck it is an excellent combo for racing
Noted & thanks.
gtr is offline
Old 02-06-2010, 09:59 AM
  #1958
K-man 15
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: nitroexpress
I will have check that out then
K-man 15 is offline
Old 02-06-2010, 03:02 PM
  #1959
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got one of the GST diffs today, holy cow these things are beefy!
However, once again, stopped by a screw. Both the front and back differentials, the the top left screw is stripped. Ican't really take a dremel to this as the screw is recessed in the plastic, I'd have to seriously damage the plastic to extract the screw, any ideas? Surely someone else has encountered this problem?
RPaulG87 is offline
Old 02-06-2010, 05:58 PM
  #1960
stussman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RPaulG87
However, once again, stopped by a screw. Both the front and back differentials, the the top left screw is stripped. I can't really take a dremel to this as the screw is recessed in the plastic, I'd have to seriously damage the plastic to extract the screw, any ideas? Surely someone else has encountered this problem?
Unless you have a good quality set of wrenches the HF screws strip very easy. I always stripped the screws until i got a decent wrench set. I never srtip them now.I think you will have to use a dremel. Those screws do come out easy when you can get a hold of them.
Wait to you put the gst pinion next to the stock pinion. You will really see the poor quality and small size of the HF pinion.
stussman is offline
Old 02-06-2010, 08:16 PM
  #1961
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ibought some of the "Grabit" screw extractors, size #1 looks like it should extract the diff screws size wise, but for the smaller ones on the Hellfire (if they do strip)I'd need the micro kit. Using a dremel...would be a last resort as I'd have to seriously cut into the plastic to extract it...I'll try the extractors when I get my drill tonight. Also, my understanding by looking at the GST, is that you take apart the GST, and rebuild it on the HPI houseing? Basically take off a part of the HF diff, replace it with the GST part, etc?And I'm guessing to get the screws out Ishould heat in the oven like suggested earlier, @ what temp and how long?Thanks!
RPaulG87 is offline
Old 02-06-2010, 08:53 PM
  #1962
stussman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: RPaulG87
I bought some of the ''Grabit'' screw extractors, size #1 looks like it should extract the diff screws size wise, but for the smaller ones on the Hellfire (if they do strip) I'd need the micro kit. Using a dremel...would be a last resort as I'd have to seriously cut into the plastic to extract it...I'll try the extractors when I get my drill tonight. Also, my understanding by looking at the GST, is that you take apart the GST, and rebuild it on the HPI houseing? Basically take off a part of the HF diff, replace it with the GST part, etc? And I'm guessing to get the screws out I should heat in the oven like suggested earlier, @ what temp and how long? Thanks!
The gst pinion and diff fit inside the HF plastic diff cups. Just some shimming is required. If you want to check/change the oil in the gst diff before putting it all together take the 4 screws out of the crown diff change the oil to the weight you want. I tried this but the screws were so tight they started to strip so i put the diff in the oven at 150 celcius for 5 mins and this loosened the locktite on the screws and they came out fairly easy.
Becarefull of the little screws on the HF plastic diff cups as they strip easy.
Remember to put some grease on the teeth of the pinion/crown before putting all together. Not to much grease.
The picture on page 57 shows exactly what it should look like before closing up the diff cups.
Rember to replace the bearings if they are worn/loose.
stussman is offline
Old 02-06-2010, 09:32 PM
  #1963
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh wow, I thought I had to take the GST diff completely apart, didn't know Icould just drop it in the HF Diff houseing, that's nice
This thing came perfectly greased, it seemed the guy just buys Genesis's and takes the part off, never been used, and oiled\greased like it just came from the factory. I don't have any shims yet, what size should Iget?You have the same truck as me so whatever you used should work perfectly
RPaulG87 is offline
Old 02-06-2010, 11:03 PM
  #1964
stussman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There should be some in your hellfire diff cups but you will need quite alot. I think they are size 13x16x.2mm
stussman is offline
Old 02-06-2010, 11:36 PM
  #1965
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: stussman
I
EFFIN
LOVE
Grabits!
Ok this thing is amazing, it worked PERFECTLY extracting the screws. One side is a re-taper it drills into the head, then you flip it around and use the extract bit on reverse, it works FLAWLESSLY, I am in love with this!I wish Ihad it whenIwas working on my chassis
Ithink EVERY R\C owner should own these bits
RPaulG87 is offline
Old 02-07-2010, 12:02 AM
  #1966
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool. Where did you get it from? Would cut down on a lot of dremeling.
KeithjV is offline
Old 02-07-2010, 02:41 AM
  #1967
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got them from Lowes, already removed 3 messed up screws with them. I did make one big mistake...Idid not heat up the gst diff...now that screw is stripped, even Grabit can't get that one out, it's just too in there, on a good note Idid discover that my Hellfire has "like new"stock diffs, the front and rear Ipopped open, and both are perfect, very little to no wear, the previous owner greased and oiled the crap out of them.
Ineed a bunch of screws now, and after being lucky with finding the Grabit, Ireally still don't want to use these stock screws, I've seen the RCSCrewz Hellfire RTR kit which are full stainless steel, won't corrode, and they claim "Never deal with a stripped head again"but the RTRhellfire screw kit from them for 30$ has 150+ ss screws.
RPaulG87 is offline
Old 02-11-2010, 09:12 AM
  #1968
sleeper341
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm having real problems with my 4.6HO over heating. It easily goes well over 310f. does any one know the standard needle settings so I can go back to the begining and retune it?
I get plenty of smoke (can't tell if it is white or blue though) when running wot but almost none around mid throttle.
I don't want to knacker my engine, so any help is appreciated.
Cheers
sleeper341 is offline
Old 02-11-2010, 10:58 AM
  #1969
nitroexpress
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HPI states factory settings are all needles flush.
http://www.youtube.com/watch?v=ma2_CghxiUk&feature=fvsr
Google is your friend.
Old 02-11-2010, 11:39 AM
  #1970
sleeper341
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Nitro, I know I should google everything really but I'm lazy I guessed if i posted here I'd get an answer that would save me trawling through google.
As for the flush settings, the HSN on my 4.6HO doesn't have a flush position as the screw is not in a 'surround' if you get my meaning. The whole HSN turns, so I wondered if i twist it one way so it won't turn any more, how many turns back would I need to do until it is at factory setting. My mid and low needles appear flush, so I guess I'll just have to richen them a bit more until I see some smoke around mid and low throttle.
Thanks again though.
Old 02-11-2010, 01:14 PM
  #1971
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well if your at 300+ temp, then your clearly wayyyyyyy to lean, so def richen it, you'll kill that engine real quickly if it's more lean than rich.
RPaulG87 is offline
Old 02-11-2010, 04:15 PM
  #1972
KeithjV
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You could also have an air leak somewhere. Check the fuel line for cracks and check the carb to make sure its tight
KeithjV is offline
Old 02-11-2010, 04:41 PM
  #1973
stussman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sleeper341
I checked my old 4.6 ho. The high speed needle sits in a black casing. If your not careful the whole casing turns with the needle. You need to ensure the casing doesnt turn only the needle. The stock settings are flush on all 3 needles. I had to seal the mid range up or it would come loose and fall out.
stussman is offline
Old 02-11-2010, 06:56 PM
  #1974
RPaulG87
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got the stainless steel Hellfire screw kit, the difference is night and day, it's like comparing a old ford to a new Rolls Royce, way more threads, extremely strong threads and heads, and they just look great on the truck. I've started taking off and replacing, a few stock ones on the lower chassis are stripped so I may or not replace those, no need for the hassle if I don't need to access that part, but these new screws I am most defiantly not expecting to strip, A+ quality.
RPaulG87 is offline
Old 02-11-2010, 07:00 PM
  #1975
K-man 15
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the low speed, mid range, and idle adjustment should be set flush with the carberator body and the high speed needle should be set flush with the groove that is on the gold stem that the high speed needle is on
K-man 15 is offline
Reply
Display Modes
