If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 81 of 87 FirstFirst ... 31717980818283 ... LastLast
Results 2,001 to 2,025 of 2155
  1. #2001
    Join Date
    Jan 2010
    Atlanta, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Official HPI Hellfire Thread
    The way I see it, and the reason Iwent with the cheaper ones and am happy with it, is aluminum is aluminum. You put the right amount of stress on it from a jump, or whatever, and it will bend, regardless of how "high grade" it is. Rather be replaceing 15$ towers than 35$ towers.
  2. #2002
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Im not arguing with you. I just wrote what Ive heard. And you are right, if you land hard enough even the "strongest" parts are going to bend/break.
  3. #2003
    Join Date
    Jan 2010
    Atlanta, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Aluminum looks great..but I do wish RPM actually had parts for the Hellfire, they make look bad, but you sacrafice looks for durability, which if you bash is a must. On my E-maxx and Rustler, Inever remotely damaged a RPM part even that one time whenI snapped the E-maxx chassis in half, only the stock points broke.
  4. #2004
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I agree. I have the RPM arms on my Savage. I wish they made parts for every RC model. They are a huge improvement over stock
  5. #2005
    Join Date
    Jan 2010
    Atlanta, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    One thing I've noticed, generally people seem to bend thier shock towers by jumping, it flipping, hitting the shock tower and bending it...since Ihave a steel roll cage on, which completely protects the shock towers (as well as engine and everything else) I'm doubting I'll be bending the shock towers, without bending the steel cage first?
  6. #2006
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would say they should be pretty safe. If you manage to bend anything under that roll cage its probably going to be from a pretty horrorific crash.
  7. #2007
    Join Date
    Nov 2009
    Battle, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: 3130pembroke
    those 4.6HO always run hot if you want to get any real power out of it- if its smokin and running hot you probably have weak compression
    what you get for a $100 motor
    Assuming that it is due to the compression, I'd look at buying a replacement engine. What would you guys recommend for the Hellfire? What are your experiences with the different engines? I don't race, I just bash.
    Thanks again for the help.
  8. #2008
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You cant go wrong with an LRP. Either the .28 or the .30. I have 3 .28's in different trucks and I love them. Tons of power and easy to tune.
  9. #2009
    Join Date
    Jun 2007
    Gold CoastQueensland, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sleeper341
    Assuming that it is due to the compression, I'd look at buying a replacement engine. What would you guys recommend for the Hellfire? What are your experiences with the different engines?* I don't race, I just bash.
    How much $ you want to spend?
    Always OFF TAP
    Finally sold my old hellfire
  10. #2010
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: stussman
    No more than $200 - $250 ideally. I was looking at the STS D30 too, how do you think it compare with the LRP ?
    thanks.
  11. #2011
    Join Date
    Jun 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The LRP 28 is a great bashing engine. If you get the pullstart version you will need to shim the engine up slightly on the mounts as the pullstart backplate gets in the way. Its no big deal tho. The bumpstart version slots straight in but you need a bump box.
    The STS engines can be powerhouses but can have crank issues. I would get the STS 28 5 port for a trug not the STS 30.
    Search around on this site .For $250 you could get a good, possibly modded 21 that would fly.
    Search on Utube for vids of engines your interested in.
    Iam considering a STS as there cheap but can be hit or miss.
    Always OFF TAP
  12. #2012
    Join Date
    Jan 2010
    Atlanta, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I know whenever my 4.6 HO Nitrostar takes a dirt nap I'll be moving to the LRP .30 more than likely, I think I'd want the extra power since my Hellfire weighs...quite a bit now
  13. #2013
    Join Date
    May 2008
    hollywood, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    everyone is correct- only the hpi SS shock tower is strong enough for abuse- I have had every brand on my truck and bent every one except the SS 7075 billet- you get what you pay for........................
    As far as motors go if your bashing why not just keep throwing the $100 axials in (same as stock hellfire motor) - change it every 7 8 gallons. then as you collect them you'll have extra carbs and parts. Make it fancy and put a nova head on it.
  14. #2014
    Join Date
    Jan 2010
    Atlanta, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'll bet you two HF SS towers that if I bash my Hellfire enough,Ican bend the SStowers
    I'd like to see where you have found the Nitro Star 4.6 HO for 100$ the CHEAPEST I have found on Ebay, is 150$ +shipping, all other sellers have them at 200+
  15. #2015
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I wouldnt spend that kind of money on an HO. For a few dollars more you can get an LRP or an SH which IMO are far better engines.
  16. #2016
    Join Date
    Jan 2010
    Atlanta, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: KeithjV
    Oh Iknow, I'm just saying, his 100$price figure is non-existant, some companies are even selling them for 270$
  17. #2017
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    You can probably find and Axial for around 100-110 but still not worth it. Spend a little more on a decent engine and you will save yourself a lot of headaches. You'll spend more time running then tuning.
  18. #2018
    Join Date
    Mar 2009
    Manson, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What weights of diff and shock oil are you guys running?
    I need to switch them out and I just want to know what would be best.
  19. #2019
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Your diff oil is going to depend on where you are driving. If you are doing a lot of straight line high speed driving then you will want a heavier center diff oil. If you are on a track with a lot of tight turns the you'll wait a lighter center diff. A good starting point is 7/10/3
  20. #2020
    Join Date
    Mar 2009
    Manson, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I usually run on a track that just has a few tight turns and some pretty good sized doubles. and i usually chassis slap on the landings, so does that mean i need heavier shock oil weight?
  21. #2021
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes Id go a little heavier on the shock oil and maybe stiffer springs so it doesnt bottom out. Unfortunately the HF is a very heavy truck
  22. #2022
    Join Date
    Mar 2009
    Manson, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I still have the 20 wt oil in my shocks from factory settings so would I want like 45 or 50 wt?
    and pink 7lb springs in front and white 9lb or yellow 10lb springs in the rear?
  23. #2023
    Join Date
    Aug 2007
    ....., NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Try the 45 and see how it goes. You might be able to make the adjustments you need with just the oil and not have to touch the springs. Its a trial and error thing.
  24. #2024
    nitroexpress's Avatar
    Join Date
    Oct 2006
    Sonoma, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: K-man 15
    A good setup will have some body slap on the biggest jumps. Otherwise you wouldn't be using all of the suspension travel. 20wt oil is too thin.
  25. #2025
    Join Date
    Nov 2009
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have 60 in mine (adjustable Hot Racing shocks with the springs that came with them, can't remember what colour/weight) and it still slaps a bit when landing big jumps.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
