x1 crt rtr questions??
PA
yes i know there are plenty of threads about this but my questions are
is the x1 truggy rtr have a powerful engine? or should i get a sportwerks .26 (i like it and i own it)
also this is what i plan to get with it off of amainhobbies
jammin x1 crt rtr
12 extra 5/10/4 rubber sealed clutch bearings (they can give out you know!) and there dirt cheap ($1 each)
jammin jp2 pipe
tonys screw kit for jammin crt
ofna 17mm half offset white rims (4 for under $20) cant seem to find ne tires on amain for these rims
lipoly transmitter battery for my m11
lipoly charger (these both both add a good $150+ not sure i need it but it will save money over time and the charger will be used for other things too)
and if i get the sportwerks motor add these
sportwerks .26 motor (pull star, but i would convert it to bump start) (also do i need a new motor mount or anything??)
sportwerks mayhem flywheel
sportwerks aluminum clutch shoe set for $16 with springs
from wat ive heard the stock engine is good but hows it compare to the stock force 28? thanks all
jammin x1 crt rtr
jammin jp2 pipe
