Servo choice for Jammin CRT
NY
Hey was thinking of getting a Hitec HS-5955TG servo for steering duties on my jammin .I could get one for $104.Would this be a good choice? thanks
RE: Servo choice for Jammin CRT
333 oz/in @ 6v.
I would call this a case of brutal overkill but that seems to be the theme nowadays. Make sure you set your endpoints properly as the mechanical limits of your steering won't stop that servo fom completing it's swing. It will literally pull your steering apart. I run a Hitec HS-5625MG @ 6v (133 oz/in) in my LSP-R w/proline maxx bowties (much heavier than the CRT) without any problems.
NY
Thanks for the help . My CRT has an airtronics 94161 in there currently , that puts out 135oz/in. Eclips, I would want a servo to put out some what more than that as an upgrade.I think the servo that speedracer1129 suggests would be a nice one@200oz/in. but for another 4 bucks could could get an extra 100oz/in. with the Hi tec i was looking at .Bone stock my CRT is steering very well although i havent run it though grass yet.i bet a 200 oz servo would be the ticket but over kill has its place Tower has the 358z for 99$. One reason i want to upgrade is that it will free up the current 94161 steering servo for me to use in the throttle brake position. Then i will be good to go.
NY
Good luck with your 5955tg. I bet it will work out great .I have the airtronics 358 on the way.I have a good feeling that ill be happy with that but if doesnt do the job for some reason, then ill go with that Hitec you purchased.Im glad the weekend is here and there was no snow this week. ill have a chance to try out my new fm radio. I want to continue running in the new engine. I have about 4 tanks through it so far . I guess running a few more tanks at a mild to brisk pace should then allow me to lean it out some.The next goody on the way is a BCE frame.
PA
ORIGINAL: AUTOMAG
wen i get my jammin crt, i will prolly get a jr 650 retails for $50 new at lhs
NY
Hey mayhem272. Hows its going? I wasnt complaining about the extra 4 bucks infact the hitec servo would seem like a good value for that price.I had some concerns about the voltage drain with that one and figured the airtronics 358z would work out great for this application.It will be several days until i get it here and install it ,so for now im running the stock servos which steer the CRT pretty well.Just checking the truggy over im thinking about cutting an opening in the winshield area to get some cool air to the engine.I also had an idea to get some screen an install it as a real radiator opening .
ORIGINAL: had enough
The servo saver will protect you steering system form any overkill you choose to install
True enough, however, many racers using high end metal gear servos nearly lock up their servo saver to acquire more consistant steering. Most of your high end, MG servos can take more abuse than your steering linkages and I'm sure a TG 330+ oz/in servo is one of them.
If you servo saver is set up for a nylon gear/horn servo then yes, it will prevent damage to the linkage. If you have the servo saver cranked nearly tight (like most of the guys I know running MG servos), your steering linkage is going to come apart before the servo saver does anything.
Truth be told, you don't need 330 oz/in of torque in a steering servo for a truggy. It is overkill and the benefits of having a servo that strong are minimal if there are any. The point of diminishing returns is achieved at about 200oz/in. I personally wouldn't seek out a 300+ oz/in servo for my truggy (monster truck, yes). If someone gave me one, I wouldn't turn it down either.
I let ya know if it rips my steering apart
ORIGINAL: AUTOMAG
NY
Thanks for ALL the suggestions. I really appreciate them allot. It never occurred to me to screen up the entire wind shield area ".Great Photo" of the beast.. ill See wich kind of screen material i can come up with and go from there
. My servo is on the way from tower and im up early to go run the Jammin.Now all we need are some 70degree days ...
