Thunder tiger ST-1
#7826
RE: Thunder tiger ST-1
Hi guys just new to this forum and new with my st 1 this site seems to be very usefull with info, Just wondering whats better the lrp28 or lrp30 do they both bolt straight up eg clutch,flywheel,engine mounts ect ect with out any modifications, Also some info on this steering upgrade is there a step by step on this forum cheers guys
#7827
NY
Either one will work great as long as you get the bump start version. If you get a pull start you have to modify the engine mounts because the engine wont sit correctly.
If you google saxton mod you should be able to find step by step instructions
#7828
I found the steering mod cheers, You say you have to mod the engine mounts if i get a pull start version in what way like grind them down or something
#7829
NY
The way the chassis is made the pull start will hit it causing the engine to tilt forward. You have to either shim the mounts up or custom make some. The bump start is a MUCH easier option. It pretty much drops right in. I had a LRP .28 in mine till it finally died. I put an SH .28 in now. I love then engine. Tons of power and easy to tune. Almost identical to the LRP as well.
#7830
Cheers for that really wanted a pull start i am guessing if i raise the mounts it would put clutch bell and flywheel outta position, Also if you could help has any1 installed a spektrum radio with telementry i am struggling to find a mounting point for the speed sensor any help would be great guys cheers
#7831
NY
You dont have to raise it that much. It still lines up fine its just a real pain to get it adjusted. Any maintnance on the engine or clutch takes longer because of the time it takes to align it. The bump start just drops right in.
I mounted my speed sensor to the center diff assembly. I put the silver dot right on the center diff. It took some work to get it to line up but it works fairly well. Ill see if I can get a picture of my set up
ORIGINAL: syko69
#7833
I just got my ST-1 Pro in the mail yesterday, will be building it up shortly. I know its an older model truggy, but the price and the quality of the kit seems unbeatable to me. I really don't see why this wouldn't be a competitve truck on the track. I still haven't picked out an engine for it yet, I've got a few in mind though. I'll try and take some pics along the way of the build.
Jon
Jon
#7834
My Feedback: (12)
MO
Can anyone tell me what pitch the stock spur is? Shredded a pinion gear on the first run of the newly brushlessed ST1. Could very possibly have been a loose mesh, but never found a solid answer on the stock pitch. Want to make sure I get the right one if that was the problem....Pinion I shredded was 32p.
Thanks in advance for any help
#7837
My Feedback: (83)
KS
I just picked up an st-1 and i'm pumped about it can anyone give me a good place to buy wheels and tires and what i need to to make it look like everyones buggy? just shoot me an email at [email protected] any help or advice would be greatly appreciated for a rookie but i love this buggy its a keeper and a racer...lol...Terry
#7838
My Feedback: (10)
MO
Your going to need a rear wing mount for the truggy look. Any 17mm wheels will work with 0 offset I believe! Also any body designed for a MBX5T will fit perfectly!
#7839
Smaller wheels (like proline MTR) with 0 offset will rub on the front turnbuckle. Look for at least 1/2" offset or bigger wheels like LPR or VTR
#7840
My Feedback: (83)
KS
I'm looking for the yellow rims and white rims? I'm wheel dumb so if anyone can give me exact numbers and where to buy the tires and rims that would be great...thanks again Terry
#7844
My Feedback: (10)
MO
Um yes, but to be honest you'd be better off getting a truggy from someone since you're new, that way you'd learn then know what to look for your next time around...That's what I did!
Had a Raze ST, then ST1, now I have Mugen Truggy...
But yes it's a good price for the race kit ST1
#7845
My Feedback: (83)
KS
Funny you mention it, i picked up a rtr st-1 on rcu for 235 and the raze st i have a hopped up one and a brand new in the box one brand new and i wished duratrax would of built on the raze st platform...
#7846
I have a super nice ST-1 I would sell if somebody wanted it. Ready to go with high speed high torque servo, spektrum radio etc etc. Has about maybe 15 tanks run through it.
#7847
My Feedback: (10)
MO
PMMe the price
ORIGINAL: ProStreetCamaro
#7848
ORIGINAL: IROC-AR15
PM Me the price
PM Me the price
PM sent
#7849
I'm a newbie and I'm thinking about a ST-1 for just playing around with. I saw two ads for one, one was a ST-1
Item #: TTR6233-F41C the other was Item #: TTR6233-F41 both same color. Also I saw ads for F42C and F42, they were a different color truck. The C versions were about $20 higher. Anyone know the difference? Also the ad calls it a Stadium truck, but here you guys consider it a truggy- can anyone explain, please? Also I'm thinking about a Redcat Monsoon, which would be better?
#7850
My Feedback: (10)
MO
ORIGINAL: Penda
Also it is by standards a Truggy, that's just there wording...It has 3 differentials which makes it a truggy. The only reason I would see why someone calls it different is because from the factory it doesn't come with a wing but they whole kit for it is only arond 12-15 bucks. I wouldn't touch the Redcat, it can't compare to the ST1 in terms of durability nor performance. Also one of the ST1 kits comes with a 2.4ghz radio system.
Just google the different part numbers and you'll find your answers but stay away from Monsoon. It's an off brand stick to the well known vendors. You'll be paying in the end if you don't. My ST1 was damn near bulletproof, I never even broke once.
