Thunder tiger ST-1
#7876
RE: Thunder tiger ST-1
Finally got to run my St1 with my Lrp z28 today my brother brught me that roto start he n i ran 6 tanks through it to brak it in n when i got to finally tune it up OMG does this thing rip it makes that stocker look like a .18 its awesome!!!! go LRP for making when heck of a mill id recomend it to anyone im going to have to retune my diffs to accomadate for all this power
#7878
ill get them on there tomorow for you bud but ill explain it the best i can for now on your stock st1 you no how the wing bolted to the body i took it off cut it exactly in half then rounded the corners were i cut it then on your a arms there is a spot to mount an additional shock you take the right side of the wing and mock it up to bolt to the left a arm and vice versa you will be placing two screws in each mudflap i beleive youll need to layout to add an extra hole and one of the exissting holeswill work perfectly in the pack with your front stabilizer youll have a ball with a hole in the center i used 1 ball pewr side to mount wich will be place inbetween the gap on the a arm but ill post pics for you
#7880
CA
ORIGINAL: kawpow321
Finally got to run my St1 with my Lrp z28 today my brother brught me that roto start he n i ran 6 tanks through it to brak it in n when i got to finally tune it up OMG does this thing rip it makes that stocker look like a .18 its awesome!!!! go LRP for making when heck of a mill id recomend it to anyone im going to have to retune my diffs to accomadate for all this power[img][/img]
Right now my poor car sits waiting its final fate. Ive debated getting it running or selling it off for parts... to bad a brushless conversion is still a bit of $$ even if I did make a motor mount for it [&:]
#7882
CA
ORIGINAL: kawpow321
so the losi 427 was a ripper huh
#7889
The posts havent been moved just marked the body and drilled, Love this thing around the track owes me alot of money and time but well worth it, Best truggy i have eva had very durable, My other body just arrived the nxt 1 should look better
#7890
what did you order another bulldog? im in the market for another myself one for the shelf that is then ill continue to put miles on this one so you didnt do anything with the front mounts at all? i was concerened with it working because it looked like it was going to fall right on a body line and not let it set flush maybee ill put them back when i do the next one so i can mount the post with both screws.. how did your sides fit do you have to pull the body out to go over the sides of the chassis? and last of all is that body for a MBX6T and i agree this is by far the best RC ive ever drivin and ive owned quit a few and with the lrp its so fun to drive my fuel jugs just keep going empty ive burnt a gallon through the LRP in 1 week that might not be alot to some but thats alot to me this thing just adores odonnell speed blend 30% loves it What do you guys run in your LRP
#7891
Posts are in there original spots never moved them, Never had problems with the sides this body fits perfectly with no mods except the cutting out and a few drilling holes, Must say they are a weapon with an lrp, We use AT RACING FUEL heard of it before im running 25% drinks like a blown v8 but runs cooler and better
#7892
kawpow321 sorry my bad proline make 3 bulldog bodies the one your looking for is PART NUMBER 3316-60 it fits perfectly over the sides and post sit in the right spot
#7893
ORIGINAL: syko69
#7894
SC
The RC8T bulldog fits like a glove! Will have pictures up of how I mounted it, fairly simple btw! Mounted the front body post on the rear of the front shock tower. My truggy also has 17mm Big Bores on it. January 1st pretty big race and I will be the only thunder tiger there
#7895
nice get me some pics gota love it the only one on the track you said you had 17mm big bores what kind and how much difference did it make im so excited i just won an auction on ebay for 61 unopened parts for mine for 52.00 just to name a few, all carbon diff cover,fr n rr shock towers,servo tray,all in carbon new chassis 6 new shocks 4 sets of cvd s center diff fr or rr diff new tank and a pile of other stuff its crazy like 500.00 for 52 plus 12 shipping i bid 165 n the highest bidder only bid 50 i thought for sure it would go for way more if it were a losi or associated it woulda sold for 300 for sure i mean i got EVERYTHING
#7897
SC
ORIGINAL: kawpow321
#7899
what are those shocks off of? and the body looks great was trying to think of a way to do my next one to sit flat like yours does i ended up just using the stock rear mounts on my first but im probably going to try n do something similar on my next could you get pics of your mounts on the rear closeups if you can but yeah looks great did any of you guys try the upper front a arms from the st1 pro out they look a little bit bulkier than the stock st1 arms
