8ight Truggy
#279
RE: 8ight Truggy
I see that some of you noticed a typo in my post in regards to my setup and good catch. I'm not running toe out on the rear, I have no idea what I was typing, I guess I confused myself. I'm running with 2 degrees of toe IN.
Integra, what wing mount is it that you're running on your 8ight?
#280
MB, CANADA
RE: 8ight Truggy
ORIGINAL: Th3pwn3r
#282
RE: 8ight Truggy
ORIGINAL: slayerphonics
Unlucklylonestars 8ight in the woods behind his house
#286
RE: 8ight Truggy
Ran the race roller half a gallon and my clutch is already toast. Opemed the clutchs and saw two worn out aluminum shoes while the other 2 are in pretty good shape. That simply means it was engaging on two shoes instead of 4. The clutch assemble was already assembled when I hooked up everything.
Can anybody tell me why this happened? Whats the best clutch set up for the the 8t?
Thanks in advance
Thanks in advance
#287
RE: 8ight Truggy
ORIGINAL: pmr
Thanks in advance
Thanks in advance
#298
FL
RE: 8ight Truggy
Just blue washers so the rod ends won't pop off,
I heard that some peoples 8ights did that so i just put washers on before it ever happened
#300
RE: 8ight Truggy
^Dang, if you're that lazy to figure it out like some of us have you're probably too lazy to install them.
Slayer, instead of that upper plate you should have gotten new shock towers, a far better upgrade IMO. Also, I think the rear shaft covers are a silly idea because all the extra drag you have now from the air resistance that wasn't there before. Kind of like running without a body.
