Official Thread for X1 CRT .5 Truggy
#51
CA
RE: Official Thread for X1 CRT .5 Truggy
I'm kinda new to this mini servo thing I have my big buggys and the RTR kyosho 09 half 8 but that was ready to go with servos but I'm now starting a Ofna 1/16 scale CRT .5 build and was wondering where and what servos to use. I would like something that won't rape my pocket book and make me feel cheap in the morning LOL just some decent servos. What speeds and what torqe ratings are normaly suggested for these little guys ???
I'm thinking of doing the pro kit then get either a JLR .12 Red dot they run about $175.00 or maybe a OS .18 but what are some of the best motor choices? I would rather build my own buggy starting with the pro kit I have heard too many wierd stories from Ofna one guy says the motor is a 3 port .12 the next says it is a 7 port .12 I here from my LHS that you can get either then next I here they only sent out a certain amount of the first cars with the 3 port which is suppossed to be a better motor than the 7 port but I want to avoid all that hoopla and choose my own power plant any suggestions on motors and where to get good prices on them.
And how does that OS .18 fit in is it a drop in or a hack in? and do you really need that much power in that small of a truck?
By the way I think this CRT .5 is one of the best little nitros to come along I kick my self in the butt for buying the Kyosho .09 ANYBODY WANT TO BUY A KYOSHO NITRO 09 RTR CHEAP?????
Any help would be great.
PS. I will be using my Spectrum DX2 TX & RX
#53
ORIGINAL: rcmxsports
Any .12 to .18 motor with a slide carb, rear exhaust and sg shaft will work. A friend of mine put an OS .18TZ in his and it fit straight in. However, the stock gearing restricts the top end a fair bit so my suggestion would be to do some experimenting. I have an OS Speed .12TZ in mine and it rips. Any hot .12 will be more than enough for this little truggy, I would recommend the OS .12TZ or a Novarossi engine if you can afford one.
Hope this helps mate.
#54
CA
Getting mine this week. Do Spektrum Rx fit in it? Getting the one w/ Picco motor. Do I need anything else for the motor to install? How do I adjust endpoints on the servos?
#55
ORIGINAL: cnguyen831
Spektrum RX does fit, I have the Spektrum micro receiver in mine to save a bit more space. It's a good idea to buy an OFNA 5 cell AAA hump pack.
You don't need anything else to install the motor. The kit comes with a collet, clutch bell, shoes, engine mounts etc.
Good luck and have fun.
#58
CA
I talked to someone at nitrohouse which is inside the OFNA building and they said december is when the RTR will come out. This kit is 80% assembled so it should be easy.
I got the Picco .12 w/ the kit. Should I sell it and get a different .12? I just want to be able to tune it well.
#59
CA
I have a choice of getting a few motors for my Ofna jammin CRT .5 1/12 scale truggy first I'm thinking of getting the JLR red dot .12
But I have found some great deals on a couple other motors one is the Orion wasp drone .12 and the second is a rare Rossi pixy R12 the Rossi claims 1.6 hp at 37,000 rpm and not sure on the wasp but it is 1.5 I believe. but is it usable hp?
My question is this. The Rossi motor sounds pretty nice but is it a well made motor is it a good match for the application I need it for? is it durable motor? I would like some feed back from some one who has had this motor.
#61
NY
Can I have a pic and link to the picco .12 you can get w/the truck in a kit, please? Who has it and how is it power-wise and tuneability?
#63
CA
which motor only gets .8 or even .6 or .7 hp
Forget this .12 stuff I just bought a OS .18 TZ with 2.2 hp on ebay now I'm thinking of getting the JP5 pipe once I sell the stocker yep then this prodject will start to move fast pun intended then next I need to gather some good servos.
Anybody have some good used servos for sale???
#64
My Feedback: (-1)
That O.S. .18TZ makes maybe 1 hp. you think you be getting even half of that HP rating, you be lucky. And numbers it's slower too, because it's a .18. Press OK
#65
CA
Ok wait a minute you say the OS .18 TZ does not make the 2.1 hp at 37,000 rpm like the factory says. Now I know all about the power thing I build race motors for motorcycles and our Hp ratings come from all kinds of sources most important where do you measure the Hp from the crank or the wheels that makes a huge difference. I can take a 5 hp motor and fool a dyno into thinking it has 20 hp with the right hemispherical conditions. And yes I know some bigger displacment motors will never produce the hp as some smaller displacment motors just because the way the two are designed.
So back to the Hp thing on these little motors. So what is a good choice. I can get the .18 TZ for 130.00 shipped a Pixy R12 for 160 shipped a wasp drone for around 150 shipped maybe cheaper and a JLR .12 red dot for around 175 I have not priced a OS .12 TZ but the one I saw was 279.00 and I thought that to be way to high for a OS then a Novarossi will be around the same price as the OS but I know that they rip I use them in my 1/8 buggies and they scream and last forever if you keep them tuned right and take care of them. Next I saw a Orion wasp .12 REV which is a on road motor for 260 something I think some one on here put one in there CRT .5
Any ways there are so many choices. I don't run these small block motors I have a Kyosho 09 and have had a 2.5 rustler 2.5 TMAXX and a 3.3 JATO but thats pretty much it on the smaller guys and a few TRAXXIS bigger guys.
So from your knowledge of running these small block motors what is a decent one to get. Or should I just get the car with the Picco 7 port .12 in it?
I know the RTR will have cheaper parts and the new .12 Ofna jammin motor in it it says that right on the Ofna web site.
#68
Is the hyper .12 motor good? I getting mine use from the lhs guy in the rc department. It's only a week old with maybe 10 tanks ran threw it. Selling for $450, good deal? Rcmxsports What company do you work for? What horse power do you think a stock RM 125 would put out. Is kawasaki going to make their KX 125 agian? How much would it cost to mod a 125? I know it is off topic but im a racer, I NEED power. #314
#69
My Feedback: (-1)
Hyper .12 is a trashy little engine. It's worse than rtr engine.
Now if it's the Jammin .12, that's a different story. Has a red cooling head.
But if it's really a Hyper .12 engine, for 450 bux, it damn well better have a M11 with full spektrum, and 10 sets of spare tires.
Seriously though, just get a new one with the engine, drop your electronics in, and have fun. You won't like the hyper .12, because it sucks.
#71
CA
Nitrohouse for the starter boxes. I got the .12 picco engine included with the kit. Can I get a pull start or shaft start for it? Or do I need the starterbox.
#73
My dad wants it more then i do. I wanted a rc10gt factory race kit and put a big .21 in it. I'll look in to a nrw one. How much does every one have in theirs to get it to run?
#74
My Feedback: (-1)
rc10gt with a big-block in it? Sorry to tell you kid, but a good .12 is overpowered in a 2wd car. You won't even get the thing to be going straight for more than 20 feet before it just spins out with a .21 in it. Hell, my MST-1 already does that, and it's got a MT12 .12 engine
#75
I'm pretty new, so i don't have the mini electronics. I have a buggy, truggy, and a rc18t. Im getting it today, i talk to my dad sbout a new one, and he said we just get a the used one and sell the motor later on. Once i get it i will take pixs and mybe a video.
